Question about Autodesk Autocad 2004 for PC
ARX_ERROR: eNotThatKindOfClass This message appears in the command line after very command and the distance command wont work
  • 72 Answers
I'm assuming you're using Autocad 2004.
Download OEHotfix.2004.exe.
Install the hotfix and restart Autocad.
Posted on Jun 16, 2009
Audio communication error on nw pajero 2013
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Sep 05, 2016 | Mitsubishi Pajero Cars & Trucks
I can not connect using grabit the error 119 code can not connect after checking most other things out I think it's the router stopping conection of this programme can help me?
Hi ....
This error message appears if:
  • An error at the TCP or IP layer has occurred.
  • The other host has gone down.
  • The network between the gateway computer and the other host has gone down.
You can test these possible causes by attempting to telnet to port 25 of the smarthost and resending the message. This can usually be done by pressing SPACEBAR and typing "25" (without the quotation marks) after the IP address on the telnet command line.
If the error message appears frequently, check the network with a protocol analyzer to determine the exact problem.
Thanks ....
With regards .....
Priya
Sep 26, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
After i use partitionmagic to merge drive (D & E ) and rename to D the Drive D disappear and wheni check error it shown Error #1520 Externak attribute header mismatch How to solve this problem
This error occurs when the PC hard disk has error(s) and your using particular software as you have mentioned like partition magic. To solve this problem shut down all your applications and running software.
If you are using Windows XP
Go to Start>Run>In the run box type cmd
A black Window will open its called CLI or Command line interface. In this Window run the following command on the C partition CHKDSK /F if the message appears"Check the system next time the system restarts (Y/N) type "y". then type "d:"to enter D partition. When the D prompt (D:) appears type the same check disk /Fix command which is "CHKDSK /F" and hit enter.
Similarly repeat this command for all the partitions.
If the this option statement appears "would you like to force dismount on this volume? (Y/N). Select "Y".
If you are using Windows Vista or Windows 7 then when you perform the first step which is Start>Run>In the run box type cmd before hitting enter in the start menu look for a small black icon named cmd on the top of the start menu. Right click it and select "Run as Administrator" When the black cmd window opens all the steps after that are the same as described above.
Good Luck!
Jul 29, 2010 | Computers & Internet
I have a G5 2.3 dual core running 10.4 I need to repair the system but have lost my install disc. Do you know where I can get one? Roderick Duncan
To start up in Safe Mode, hold down the shift key and then startyour Mac. Safe Mode takes a while, so don’t be alarmed when you don’tsee the desktop right away. While you’re waiting, the operating systemis verifying the directory structure of your startup volume, andrepairing it, if necessary. It will also delete some of the startupcaches that may also be preventing your Mac from starting successfully.
Once the desktop appears, you can access and run disk utility http://macs.about.com/od/applications/ss/firstaid.htm tool just as you normally would. When First Aid is finished, restart your Mac normally.
Please note that not all applications and OS X features will workwhen you boot into Safe Mode. You should use this startup mode only fortroubleshooting and not for running day-to-day applications.
Boot Into Single User Mode Start up your Mac and immediately hold down the command key plus theletter ‘s’ key (command + s). Your Mac will start up in a specialenvironment that looks like an old-fashioned command line interface(because that’s exactly what it is).
At the command line prompt, type the following:
/sbin/fsck –fyPress return or enter after you type the above line. Fsck will startand display status messages about your startup disk. When it finallyfinishes (this can take a while), you will see one of two messages. Thefirst indicates that no problems were found.
** The volume xxxx appears to be OK.The second message indicates that problems were encountered and fsck attempted to correct the errors on your hard drive.
Sep 30, 2009 | Apple Power Mac G5 Desktop
I am having the same difficulties as you!
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=c00220758&product=12455
If you have compressed the hard disk drive using the Compress drive to save disk space option under the Properties menu for your hard disk drive and have performed a non-destructive recovery or a system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved by following these steps:
  1. Insert the HP Recovery Tools CD or Compaq Recovery Tools CD into the CD drive on the computer and restart the computer.Wait for the HP Recovery Tools CD or Compaq Recovery Tools CD window to open.
  2. Select Run Microsoft Recovery Console , click Next , and then follow the onscreen instructions. NOTE: If you are unable to open a recovery console, follow the Alternate steps .
  3. Press R to repair the Windows XP installation using Recovery Console.
  4. Enter the appropriate number for the WINDOWS installation, for example, the WINDOWS installation could be listed as 3: C:\WINDOWS or 3: D:\WINDOWS .
  5. If prompted, enter your Administrator password and press Enter . If there is no password, just press Enter .
  6. At the prompt, if the WINDOWS installation you selected in Step 4 was C:\WINDOWS, type: cd c:\Or, if the WINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cd d:\
  7. At the prompt, type: attrib -c ntldr and then press Enter .
  8. At the prompt, type: exit
  9. Press the Enter key and immediately remove all discs or diskettes from the computer to allow the computer to restart.The error message should be resolved.
Alternate steps NOTE: These alternate steps work for HP and Compaq desktop PCs with Windows XP and a recovery partition. (M0st HP and Compaq PCs with Windows XP have a recovery partition on the hard disk drive.) These steps do not work if you have replaced the hard disk drive, replaced Windows with another operating system, or repartitioned the recovery partition.You can use the following steps if you are unable to open a recovery console:
  1. Turn on the computer. When the initial logo screen appears, press the F10 key repeatedly until a message about starting recovery appears.
  2. At the Recovery screen, click Advanced Options and then press the Alt and D keys at the same time to go to a command prompt.
  3. At the command prompt, enter the following: diskpart
  4. At the command prompt, enter the following: list volume
  5. Remember the drive letter next to line for the main hard drive; HP_PAVILION or PRESARIO.
  6. To close Diskpart, enter the following: exit
  7. At the command prompt, enter the drive letter followed by a colon (:). For example, H:
  8. At the command prompt, enter the following: cd \windows\system32
  9. At the command prompt, type the following: compact ntldr /u <the drive letter>:\ntldr For example if the drive letter was H, you would type: compact ntldr /u h:\ntldr
  10. Type exit and press Enter .
  11. Click Quit .The error message should be resolved.
Sep 06, 2009 | E-Machines eMachines Desktop PC
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Fatal error internal error 2738
Hi Bo,
This usually happens in Vista machines. Try the steps below and see if it works. Let me know if u get stuck or it dosent work. Mentioning the manufacturer and the model number will be very helpful too.
  1. Search for the VBSCRIPT.DLL file on the computer. It is usually located in the C:\Windows\System32 folder.
  2. Click the Start icon (c01319360.gif ) , click All Programs , and then click Accessories .
  3. Right-click Command Prompt , then click Run as Administrator .
  4. In the command prompt, type CD C:\WINDOWS\SYSTEM32 . If the VBSCRIPT.DLL file is located in a different folder, use the appropriate folder location.
  5. Press the Enter key.
  6. Click Continue in the window that appears on the computer.
  7. Type REGSVR32 VBSCRIPT.DLL in the command prompt and press Enter . A message appears on the computer indicating that VBSCRIPT has been installed successfully.
Cheers
Oct 09, 2008 | Office Equipment & Supplies
Computers & Internet Logo
833 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Alex Krenvalk
Alex Krenvalk
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
