Question about Garden
Need setting for points - Garden
  • 125 Answers
Try 10 thousanths
Posted on Jun 16, 2009
Do I need a PayPal a/c to. Collect nectar points from. Ebay
Hi Peter
No you don't need a paypal account.
To convert Nectar points into eBay vouchers ("vouchers"):
  • You need to have linked your eBay and Nectar accounts for collecting points;
  • You need to log into your Nectar online account and authorise eBay to set up your account for spending points;
  • *You need at least 500 points to redeem your points for a voucher.
Aug 18, 2017 | PayPal Computers & Internet
How do I set points and condenser on hyosung Mx 125
Hey Maryna, This is a job for a professional,, the timing is critical so engine damage doesn't happen!!.-- BUT, if you have someone who has the tools.. you can do it yourself.
The points control the time the spark plug fires. The point gap makes sure the spark is generated is sufficient enough to provide the energy to the coil to provide the hot spark to the spark plug.
The timing should be around 1.8 - 2.0 mm BEFORE top dead center..(the piston location). When the piston is at 1.8 - 2.0mm BTDC the points should be just breaking contact.. this is the ACTUAL TIMING setting!! You need a dial indicator with attachments to fit into the spark plug hole AND a meter to tell you when the point first open.. The points gap should be .014".
Some engines use the point gap as a timing setting...ie.. if the point gap is right (.014") the timing should be close. The timing has to be very close...too advanced (2.2mm BTDC or more) and you will burn a hole in the piston!!!! IF you set the point gap and the timing is off, you need to replace the points. There should be some timing marks somewhere on the flywheel/engine case. If you need more help,, just reply to this post. Good Luck!!
May 24, 2015 | Hyosung Motorcycles
Timer cuts on , but will not turn off
assuming that this is a mechanical timer with set points for off and on red points turn on and black points turn off. set the red point for your on time and then be sure to set black point for off. Best to tighten 1/8 turn (slightly) with pliers so it does not slip
Nov 11, 2013 | NSI Tork Timer Switches | Tork 1104-FM...
What settings do I need for plugs & points on Wisconsin motor for riding lawn mower
Hi, 15 thou on the points and 30 thou on the plugs. Regards Phil.
Jun 13, 2012 | Garden
I have a nokia c1-01 and when want to browse, Iam asked to subscribe to packet data first and I do not know how to go about it.
You need to ask your Service Provider if you want to subscribe for packet data connection.
Once you are subscribed, they will provide you Access point to access internet. You can use that access point to browse the web, just set it as default access point.
In case you aren't provided with the access point, you may need to configure APN by creating an access point on your mobile in order to browse web.
Aug 11, 2011 | Computers & Internet
Getting the internet on
first you need to set up your Connection Settings under "Internet" in the System Settings Menu. Then you need to either "Search for an Access Point", in which your system will search for a nearby Wi-Fi hotspot, or choose "AOSS". When "Searching for an Access Point" turns up results, they'll be accompanied by a padlock icon that either shows as being locked (the WEP access code is needed) or unlocked (free access). If you're trying to set up access to an AOSS-compatable access point, then you'll need to press the AOSS button on the access point until it flashes.
Aug 02, 2010 | Nintendo DSi Black Console
Need to set the timing on a 1978 kawasaki 650kz. how?
you have 2 sets of points one set attached directly to main backing plate the other set has another backing plate attached to main backing plate .start with the first set turn motor till points at the widest gap set gap to0.35mm turn motor back till points close diconect push on terminal and attach multimeter lead to points terminal attach
other multimeter lead to earth tun motor to the points break continuity with earth check position of f mark to pointer move backing plate till points break contact on f mark now do same to next set of points nb if points worn you might have to run a much smaller gap 2 get rite!
Jul 20, 2010 | 1978 kawasaki Z 650
How do I set an access point for my multimedia messages(NokiaN70)
access point setting doesnt cost u anything....neither receving a multimedia message...only if u sent a multimedia message costs u depending on operator tariff
u can set up an acces point by 2 ways
1.manually...if only u know ur access point..then u need to go in multimedia settings and enter access point
2. ask ur operator they will sent u the multimedia settings with access point..via text message n u can save that automatically
Sep 21, 2009 | Nokia N70 Cellular Phone
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
