Question about Samsung HP-R5072 50 in. Plasma HDTV
Bottom half of picture cuts out?
I have a hps5053 samsung.the bottom half of the screen cuts in and out and then sometimes just stays blacked out?
  • 199 Answers
This is most likely a "cold" solder joint on one of the components, i.e. capacitor, inductor, ect. If you are handy with a solderiing iron and disassembly and more important reassembly, then you could reflow the cold joints. I hope this helps. Good luck :)
Posted on Jun 16, 2009
Bottom half of screen is black
The display strip is not properly seated in the connector base. That is a hardware problem so dont think of a software error.
Oct 07, 2014 | Samsung Un46eh6000 46-inch 1080p 120hz Led...
Samsung LNT4661 FX/XAA when you turn tv on picture is ok after a few minutes bottom half of screen puts red tint horizontaly across screen it will sometimes go away after 15 or 20 min. What is the...
Hi there are two things that could be causing these this. Either your t-con board is bad or your screen is bad. Since screens are so expensive I would replace the T-con board to see if that fixes the problem.
You can get parts for this TV at www.interliquidparts.com
Feb 29, 2012 | Televison & Video
I am having a problem with my picture on the top
NEED REPLACED SU BOARD Manufacturer Panasonic Part Number TXNSU1HNTU Description PC BOARD
Feb 17, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
My 50'' Samsung Plasma has dead screen after only 2 years
welcome to fixya!
without doing voltage checks, my best guess is this:
Plasma hpr5053 or hps5053 models will burn out a buffer board or both, there are two buffers and the Y board.
I usually change all 3 at once, but if on a budget you can try to remove one buffer and see if you get half picture (upper or lower)
this is something only a technician should attempt. the boards cost $200 each (buffers)
$300-$400 (Y board).
if you actually get half a picture the Y and one buffer are good, a bad buffer usually burns out the Y board. and in really bad cases the panel is bad also (not common, but possible)
For part#s , specific help you can post a model# , but again this is a repairmans job not something the average customer can fix.
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 27, 2009 | Televison & Video
Fault with Samsung PS42S5H
sounds like the lower y-sus buffer! take off the back and give me the pcb number should start with Lj92
Nov 03, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Black on bottom of screen
do me a fovor, i need your firmware version? to do this, press Input 619. in the center of the bottom of the screen, is three digits 5?.? please provide me with these numbers. you may just need firmware updates.
Sep 28, 2008 | Dell W5001C 50 in. Plasma HDTV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Samsung HP-R4252 42 in. HDTV screen black outs and red lines
Hi: We had this problem under warranty, and tech installed the following to solve it: Parts BN96-02033A, BN96-02034A and BN96-02216A. This solved the problem for 2 years. I now have the upper half going black now and then for 2 to 3 seconds. I am ordering these parts from www.partstore.com and will just plug them in. Better than a new tv.
May 25, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
268 people viewed this question
Jerry Greenberg
Jerry Greenberg
