SOURCE: setup cannot find office.en-us/dwtrig20
heyy..if u encounter this problem then just go the folder and open the
file whichever ur setup cannot find and then retry.for example if ur
setup cannot find dwtrig20.exe, find it in the setup folder and open
it..then try installing it again.in most cases, the setup will not b
able to find 2 files. open the two files whenever the setup cannot find
them and then install.
this will surely work
SOURCE: setup cannot findOffice.en-us/dwtrig20.exe
microsoft office setup cannot find office.en-us/dwtrig20.exe
SOURCE: asking to locate '' office.en-us/dwtrig20.exe''
do you have any other ms office software installed in the pc? if there is, uninstall them. then follow the steps below.
hold down the window key + the R key on your keyboard. type regedit on the run command line then press enter
locate the following:
HKEY_LOCAL_MACHINE > software > microsoft > office, cleaned up both the 12
keys and the downloads keys further under delivery > source engine
> downloads (right click on downloads, choose rename. change it to downloadsold)
press enter then reboot pc.
SOURCE: during installation of ms office
download dwtrig20.exe
http://www.4shared.com/file/FnkzXr3u/dwtrig20.htm
SOURCE: need to re-install ms office 2007-get setup.CHM
The setup.CHM error appears when the previous install is still there in some form. Run the uninstaller if it still appears in Programs, then manually locate and wipe all the Office folders left in in C - especially those in Docs and Settings. Now reboot and run install and run a cleaner like this one. Now reboot once more and install and run a registry cleaner like this one. Reboot once more and you will now be able to reinstall.
