Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Solid Black line down center of ipad - Hitachi 42EDT41 42 in. HD-Ready Plasma Television
4 Suggested Answers
SOURCE:
SOURCE: Black Line down center of screen
Had the same problem.  Was quoted $800 to fix.  Searched the internet for 6 months and found this thread on avforums.com
http://www.avforums.com/forums/showthread.php?t=462873&highlight=black+line+on+plasma&page=4
Read through all the posts.  Very simple fix, but you have to have some mechanical inclinations or you can cause more problems than you started with.  I was up to 5 of the black lines, but decided to attempt the soldering these guys did and fixed it all for the cost of a soldering iron!
Posted on Oct 12, 2007
thaurfen
  • 623 Answers
SOURCE: Black Line Down Center of Screen
Dry solder joints on the pins of the vertical integrated circuit may have caused this problem Tap each I/C lightly with a plastic screwdriver handle to find the intermittent one. It is the one with a heat sink attached.
Posted on Aug 10, 2008
SOURCE: Black line down the center of screen
I had the same problem to and I fixed it.
At the bottom of the plasma there are six or seven ribbon cabbles that come out of the panel and connect to like driver boards. Each ribbon drives that section of the panel. Mine had it down the centre so I unplugged that ribbon cable and on the underside of a metal plate attached to it there are four big resistors and four small ones. The big ones labelled 100 required resoldering. Once they were resoldered it worked just fine.
Posted on Sep 24, 2008
There is a solid black line in the middle of the tv when i connect my ipad to it
Check and replace all the electrolytic capacitors in the vertical deflection output circuit. There will be 5 or 6 of the. Replace all at one time. The problem is to the vertical output stage.
Sep 28, 2012 | JVC AV-32D305 32" TV
Panasonic plasma 1 solid black vertical line left of center
faint chance here, the larger or thicker the line the worse it is. Usually this is a defect inside the panel where it cannot be gotten at---rarely this will be a plug or connection outside of the panel.
The screen unit or display panel costs more than the set did new.
Sep 01, 2012 | Panasonic Televison & Video
Thin coloured lines running down center of tv. Panasonic Viera.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP TO SOLVE THE PROBLEM.....
Aug 07, 2011 | Panasonic Televison & Video
A Solid black line down the left side of the page
It could be 2 things...
1. Your scanner glass is dirty...open the doc feeder and clean the glass. probably Wite-Out.
2. A segment of your scanner assembly lamp is burned out. Not good, uneconomical to repair.
Jan 21, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Black line down the center of the tv wont go away
Sorry, justindorval;
I did not complete my questions.
4. Does line move when the channels are changed?
Good luck, big IRISH. ps let me know, I'll more happy to help you.
Jul 19, 2008 | Televison & Video
Oct 10, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
did you fix the black line? please let me know as my TV (same model) has the same problem.
Jul 14, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
14 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
