Question about Sanyo PLC-SW30 Multimedia Projector
I plugged in a ps3 and i can not get the input to work?
  • 43 Answers
What input method are you using? Composite?
You may need to manually select the input on the projector.
Posted on Dec 03, 2009
The av2 input doesnt work
Look for any loose contacts in RC jacks/sockets/Cable. Connect another input on that input of the TV and check. Connect your ps3 to some other TV and check.
Aug 05, 2012 | LG 32LG30 32 in. LCD HDTV
PS3 wont display using HDMI ports and Input connection on PT-52LCX66
It would seem either a setting at the ps3 or the set is not right.
Good idea to check all inputs and setup again--if something like a DVD works on rear input issue is with the PS3.
Mar 14, 2012 | Panasonic PT-52LCX66 Projection Television
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
My Ps3 was working great but now I get a no signal message Please help! Thank you
Make sure your tv is on the same input as your playstation is. You can press input on your tv and change it to the right input. Also you can totally turn the ps3 off and unplug from the wall. Wait 20 sec and plug it back in that will reset the video on the ps3.
Mar 20, 2011 | Sony Playstation 3 (PS3) Console
AWe are attempting to play PS Three, but the Inputs on the front and back of tv for the RCA cables arent working. What should we do to make the inputs work?
change the input, i have the same configuration ps3 and 52 inch rca, just plug it into front and change the input to front, if that dont work try this, since your ps3 probably came off a tv that had hdmi you need to hold down the ps3 button for 9 seconds and it will ask you if you want to change it to lower settings, but first make sure you have the input right
Sep 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Greetings- my denon avr2802 is connected to ps3 for blu ray movies, games and music. The ps3 image goes directly to tv with hdmi and sound from ps3 goes to the denon using digital audio cable. Sound for...
Set the receiver for auto audio input - I think that you are getting caught out between MPEG and DTS audio. If you have the wrong one for the audio source then you hear nothing.
Mar 07, 2010 | Denon AVR-2802
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Jul 08, 2009 | LG M227WD-PZ LCD TV
PS3 no longer works
are you able to see the cable/sat...or dvd? if so the input your ps3 is on may be bad try another input on back of tv..if this does not work you may have to call sony
Feb 23, 2009 | Sony Playstation 3 (PS3) Console
Sanyo PLC-SW30 Multimedia Projector Logo
127 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
