Question about Kenmore Elite 45986 Front Load Washer
Error codes F35 and SUB when washer is started
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
    New Friend:
  • 4 Answers
I had this error a couple of times too. The first time I encountered it I got a "SUDS" error and a few minutes later F35. I replaced the pressure switch and it worked great. I recently had the exact same symptoms. I replaced the pressure switch again, no change. Ordered another switch (in case the first new one was bad) - no luck. Ended up having to replace the master control unit. I now have two of the pressure switches and am selling them on eBay at a substantial discount. Go to: eBay Link
-or-
Go to eBay and search for the part number (W10415587). Mine is listed for $50 or $65 instant buy.
Posted on Sep 13, 2013
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: washer starts to begin wash cycle then says suds then error code f35 appears then washer shuts off
The "SUDS" error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Obstructions in the drain pump and/or drain lines can attribute to air getting trapped in the drain pump and cause the error code. Double check all electrical connections to the drain pump and Central Control Unit (CCU). You will need to remove the top panel of the washer to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, slide the panel back, then off. The CCU is located directly behind the wash tub in the center of the washer. The Drain Pump connector will be the 6th connector (facing from the front L to R) in the center of the CCU.
3. Check the Pressure Switch to ensure it is good. The Pressure Switch is located to the right of the CCU as you are looking from the front. It is a small cylindrical shaped device with a connector plug and an air hose attached. The switch can be checked at several water levels by removing the plug and taking resistance readings at the connector pins. Readings are as follows:
(Pins are numbered R to L facing the from the REAR)
Pins 1 to 2 (SUDS Detect) – 0 ohms
Pins 3 to 4 (Overflow) – 0 ohms
Pins 4 to 5 (L1) – 0 ohms
Pins 4 to 6 (Empty) – 0 ohms
Fault code F35 on my washer what does it mean?
The F35 error code indicates an analog pressure sensor error. ... This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem.Jun 3, 2011
SOLVED: F35 error code appears during cycle - Kenmore Elite HE3 ...
https://www.ifixit.com/Answers/View/54204/F35+error+code+appears+during+cycle
See this link and watch the videos
Fault code F35 washer Google Search
Jul 31, 2018 | Washing Machines
What is the solution of error35 in w455h washing machine
Hi! If you mean error F35, this error code indicates an analog pressure sensor error. This sensor is the component that detects water level in the washer tub.
F35 error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor.
Apr 27, 2017 | Washing Machines
I have a Whirlpool Duet Washer, washer starts and then stops code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi After a year of using my Kenmore Elite HE5T washing machine, Model #110 47789701, serial #CSW2733428 I am getting an error F35 and Sub. Could you please let me know how to fix it? Thanks Barb
Kevin
Jun 15, 2011 | Kenmore Elite HE5t Washer
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F35
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer. I am not aware of other uses of the F35 code on the various models. If you intend to diagnose and repair this problem yourself, I recommend resubmitting your question with the full model number of your Kenmore washer so that we can verify this technical information using your model number.
Jun 08, 2010 | Kenmore HE2 Plus Front Load Washer
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F35
May 18, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
711 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
