Question about Pool & Spa
Water way hi flow pump for above ground pool has rusted shaft and
Motor turns on, but, fan wont turn do to rusted shaft , how do i replace shaft
    President:
  • 1,378 Answers
The most cost effective way is with a new motor. You can contact us at www.arrowmotor.net for a price quote on the replacement and/or pump parts. Please include and model numbers off your pump with the email.
Posted on Jun 16, 2009
Pump runs but humms
Question:
What do I do if my pool/spa pump is humming and has low flow?
Answer: by Osko Pool n Spa Pool/Spa Pump Humming and No Flow If your Swimming Pool or Spa Pump Motor is humming and/or has very little or no water flow, please follow the following directions.
1) Remove the pump motor from the system.
2) Disassemble the front half of the Pump Pot Housing from the back half.
3) Check for any foreign obstructions which would jam the Impeller and remove it
4) Next, inspect the Pump Motor Impeller itself. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged and requires replacement.
5) Next, remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged and need replacement.
If everything seems to be in good working order, then you need a new pump... not just replacement parts.
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 15, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
Pool pump is humming but fan will not start spinning.
Causes are bearings, debris, windings, or capacitor.
Cut the power and remove the rear end cap covering the motor shaft. Use a 9/16 wrench to turn the motor shaft back and forth. Sometimes this will unseize the bearings. If it gives a lot of resistance the bearings are shot or there is debris jamming the impeller.
The capacitor may have blown out. This is under the cover that sits on top of the motor. See if replacing works.
If all seems okay otherwise, your motor has lost (opened or shorted) some windings and needs to be replaced.
Apr 02, 2013 | Waterway Twm Above Ground Pool Pump and...
Switch is turned on but pump would not run. shaft turns by hand
It's junk made by Hayward. I've gone through two motors and am starting to hear the familiar noise of another motor about to fail.
Jul 05, 2012 | Hayward Pool Products Economy 1 Hp Above...
Intex Automatic Salt Water System For Above Ground Saltwater Pool won't turn on
Usualy if it is some years the ball bearing on the motor shaft are rusty and if you can desasemble and use a UD40 lubricant or similar it can be fixed, or replace the bearing. One more posible case is the starting capacitor if it replaced can run the motor again.
Jun 05, 2012 | Intex Automatic Salt Water System for ...
I have a proline 1.5hp pump need to replace the shaft seal. I can't seem to get the plastic impeller off. We use a screwdriver to hold the shaft screw and try to turn the impeller counter clockwise...
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
May 15, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
Pump stopped working
Inside the back case on the motor you'll see a white piece with two copper colored arms that have two silver points that almost touch. If these are rusty I've found that the motor won't turn over
. A quick fix is to take some 600+ grit Aluminum oxide sandpaper and give each of those contact points a brisk sanding to remove any oxidation. This will help the points make a positive contact . Make sure while very obvious that the motor is unplugged first.
If your pump has been leaking water it could be that rust has formed on the inside and is preventing the motor from operating properly. Which requires more aggressive dis-assembly to diagnose.
You can take it to a motor repair shop if the above listed doesn't work
Aug 14, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Swimming pool pump wont drain above ground pool
you are clogging your impeller take a wet vac put hose your using for pump in pool put vac on end of hose to woods and turn on vac long enough to get a water flow and shut of vac it is slower but will save pump
Jul 07, 2009 | AO Smith A.O. Smith Threaded Shaft 1 HP...
Dynamo pump is locked--just hums
Try turning the motor from the back. Remove the end cover and turn the shaft. If it still hums the motor will need to be replaced.
Apr 27, 2009 | Pentair Dynamo 3/4 Hp Above - Ground Pool...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
