Question about HP Compaq Presario C306US Notebook
Compaq presario shut down while plugged in
I have a three-year-old Compaq Presario C306US notebook. I do not connect it to the Internet or use other people's software or discs. I operate it plugged in virtually all the time. Recently I operated it on battery for two or three days. I've used it since plugged in, but the screen was dimmer than usual. Tonight I was using it plugged in, when it died out. I can't get it to boot up again. A yellow light to the left under the keyboard blinks, and it then shuts down. The plug area isn't even getting warm.Can you tell me what is going on, and what I can do about it? Do I need to replace the battery?
  • 555 Answers
Greetings my friend, regarding on your problem try to remove your battery then clean it and after you clean insert it back. then used the power connector and insert it in the DC plug and wait for 5 - 10 mins before you turn on your laptop. In that way the battery is already charging then try also to touch the battery of the laptop if it is charging or not by touching the battery and when it warms meaning it charge otherwise it is not charging. Then if your findings are true that your battery are not charging then try to test it with tester so that you check the status of your battery.
Posted on Jun 16, 2009
Display on Compaq Presario V2665US notebook cuts in and out.
BIOS does the screen fail in BIOS< no OS running?
power on hit ESC, F10 or what it told you to hit for 11 years.
does BIOS work
that button top left is the standby sleep switch .
if bad , no sure what will happen, but something wrong will.
the aCID TEST IS BIOS.
works on demand all the time or not.
LAMPS:
the back lamp is dead, CCFL
all do, on all old screens 2010 and older
the magic year is 2010 as that year LED phased in.
see? use flash light see, that data there? do you'?
no sure what button you are pressing?
an 11 year old Laptop 2006, so CCFL is there
test those.
for sure use a flashlight.(test)
and see if there is data if see that, the CCFL tubes dead, there inverter is dead, or the power to it or out of it is cut.
here is close manual for free.
https://www.manualslib.com/manual/30176/Compaq-Presario-V2605tn.html
Nov 28, 2017 | Compaq Presario V2665us Notebook
My old hard drive on my COMPAQ PRESARIO C306US died, after I replaced the drive I tried reloading windows XP and I get an error that the hard drive could not be found. I loaded Ubuntu and it recognized the...
check the HD if its properly inserted,if the old one is working before then the new one you bought my be a damage one. try to replace another HD to see if which HD is working or not.
Jun 06, 2011 | HP Compaq Presario C306US Notebook
Can i up grade the hardrive for a HP Compaq
Yes the bios will identify the hdd without problems
Jul 01, 2010 | HP Compaq Presario C306US Notebook
I get a bluescreen on startup that says a problem has been detected and windows has been shut down to prevent damage to my computer.PAGE_FAULT_IN_NONPAGED_AREA
Most blue screens are due to a memory failure...try to remove the memory cards and just replace one at a time to see if you have a bad module or slot.
Jan 29, 2010 | HP Compaq Presario C306US Notebook
Compaq presario f700 sudden shutdown
Less than one year old? Then, it can be fixed at NO COST to you, via "warranty" from the vendor.
Apr 12, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Compaq presario c306us doesnt format, says there there is no HDD
dear friend
you need to goto bios and search for and option "sata native support"
set it to disabled
if you cant find that , then you need to splitstream sata drivers into windows xp cd, if this is the case please ask me to tell you the method
thanks
Apr 10, 2009 | HP Compaq Presario C306US Notebook
Battery doesn't stay charged
The problem is with the battery. All Lithium batteries last for around 1000 charges or so. Since the laptop is 2-years old the battery needs to be replaced.
I Hope this solves your problem. Kindly Accept my solution.
Regards, Arjun
Apr 01, 2009 | HP Compaq Presario C306US Notebook
Does the compaq presario c306us have a dvd burner?
Here is that model HP link . You can download a manual or the specifications to answer the question
Mar 18, 2009 | HP Compaq Presario C306US Notebook
Problem with bluetooth on compaq
normally if you turn on Wifi then it will automatically turn on your bluetooth defice. or install the HP wireless assistant
Apr 02, 2008 | HP Compaq Presario C306US Notebook
HP Compaq Presario C306US Notebook Logo
79 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
