Question about Sony PS-LX250H Turntable
How do I adjust speed of Sony turntable model PS J11 it's slow underneath there are two circles with + and -  33 rpm and 45 rpm looks like you insert something (a pin or allen key?) but I can't figure it
    Sniper:
  • 79 Answers
Try a skinny flat screwdriver, like one you fix glasses with. Lemme know. Please rate me
Posted on Jun 18, 2009
Adjust pitch not working on PS T1 Sony
Try looking underneath the turntable. There might be two speed presets one for 45 and one for 33. They could be covered up by stickers.
Jun 04, 2014 | Sony Audio Players & Recorders
How do I adjust the speed of a Sony LX250H turntable? The answer is not in my manual.
Presumably you mean correcting the speed to play 45 and 33 correctly?
Some turntables have the speed control(s) as a preset(s) built into the base on the underside of the unit. Often covered with a sticker. You simply remove the sticker and stick a small screwdriver in the thing and turn it.
Others have the preset inside on a circuit board, got to by removing the bottom of the turntable. Others have it built into the motor itself.
You should replace the belt first if the speed is slow on both 45 and 33, before adjusting the motor speed.
Apr 25, 2014 | Sony PS-LX250H Turntable
The speed control switch does not affect the play speed of the turntable. It only turns at 45 RPM (switch open.)
It's likely the belt has come off the correct position. It would need to be adjusted. One reason it's moved is that it needs replacing, because it's too slack.
Apr 19, 2013 | Sony PS-LX250H Turntable
Sony ps-lx250H turntable only spins at 45 RPM
It seems to me that the switch has broken and isn't moving to the 33 setting. You just need to find the switch. Without seeing it I can't say what type it is so I suggest looking for it under google image search. Try "micro switches" or "leaf switches". You can also look try Maplin, or the Curry's Partmaster website.
Nov 11, 2011 | Sony PS-LX250H Turntable
I have a Sony PS-LX210, and need to adjust the speed. Going by the music it's played, it's just a bit slow on 33 RPM (I don't know about 45). I find no external adjustments, but there are some trim pots...
According to anything I can find online, like any decent turntable it has a manual pitch control. Unfortunately, I can't find a manual or even a good close-up picture.
This is the best one I've found.
http://www.neowin.net/forum/topic/652451-post-your-vintage-tech/
What's that rectangular slider-looking thing at the front right edge?
Feb 10, 2011 | Sony PS-LX250H Turntable
My turntable speed is too slow. I have the optimus lab 1000 and there are speed adjustments on the bottom side of the unit but turning these either for 45 or 33 rpm did not change results. I have already...
Look under the platter or on the bottom of the turntable. There should be two adjustment holes for 45 and 33. You will need a small screwdriver for adjusting these. If this does not work clean the control pots with spray cleaner.
Dec 01, 2010 | Radio Shack Audio Players & Recorders
My Sony PS-LX250H is all of the sudden playing too slow with a 33
Not sure what made it happen all of a sudden, but you might want to check out Mocamom1 's question related to PS-LX250H speed & the attached solutions. You may just need to adjust the SW screw on the underside of the unit (worked for mine that was playing everything at 35 1/4!)
Jun 27, 2009 | Sony PS-LX250H Turntable
Sony PS-LX250H speed problem
I have a different Sony model (PS-LX-150H) that had a similar problem. I hadn't used it in awhile, and then when I did, I noticed the speed problem.
IF your PS-LX250 is like my PS-LX150, there are small speed adjustment screws accessible from the bottom of the unit. On mine, the two adjustment screws were labeled - one for 33rpm, the other for 45 rpm. Basically I just fiddled a bit with them using a very small precision screw driver until I could verify that I had reached 33 rpm (I used a stopwatch and literally counted the number of rotations/minute after making adjustments.)
Now it sounds right!
Mar 09, 2008 | Sony PS-LX250 Turntable
Sony PS-LX250H Turntable Logo
1,088 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
