Question about Insignia Digital-to-Analog Converter for Analog TVs
Can't get digital converter box to work with Toshiba TV/VCR Combo
In April several of our local stations (NBC, ABC) started broadcasting in digital.  We bought a digital converter and hooked it up and everything was great. This June when all stations went digital NOTHING works.  Can't get on screen menu or picture.  VCR works fine to play a video.
  • 87 Answers
You will need to rescan your stations. On the June cutoff date, they reshuffled and renumbered most of the stations.
Posted on Jun 16, 2009
How do I get free local TV over-the-air stations?
The Quasar VV-2002 only has an NTSC (analog tuner). Very few stations with NTSC transmitters are still broadcasting. Only low-power stations were allowed to continue broadcasting an analog signal. Unless you are very close to one of the transmitters, your TV will not tune in the station.
You'll need to connect the TV to a digital-to-analog over the air converter box. (The low-end ones that were free or cheap with the government coupon are harder to find; a few models are still available.) These convert the ATSC (digital) signal to NTSC. Then use an appropriate antenna and follow the instructions to tune in the available OTA signals. Send these to the TV either on the RF or composite Line-in. Set the TV to the appropriate input and use the converter box to change channels.
I hope this helps.
(20" TVs weren't required to have an ATSC tuner until 2007. Since there are reviews for the VV-2002 from 2004, it obviously is an older set.)
Nov 19, 2015 | Quasar VV-2002 20 in. TV/VCR Combo
I got a used Toshiba CZ32T31without a user manual. When I hook up the cable all I get is snow. I also can't get local broadcast when I move the channel to the station number.
If you are in the USA, all free broadcast channels are digital, so you won't get anything without a digital converter box. In Canada, some channels are still available without the box till August 2011.
The tuner may be defective. Use a VCR or cable converter with audio/video outputs and connect them to the appropriate inputs on the TV, use the VCR or converter to change the channels.
Jan 04, 2011 | Toshiba CZ32T31 TV
Do I need a digtal converter box to pick up local stations via antenna?
Some local broadcasting will still be in analog but this is just jor simple programming such as college stations. To get local programming such as NBC,ABC,CBS etc. you will need to get a converter since the government has mandated all broadcast be in digital to free up air space.
Note that it may be a case by case basis for some smaller areas.
Dec 29, 2010 | GE 31GT720 31" TV
I have a CRAIG 13 INCH HIGH DEFINITION LCD TV MODEL #CLC503 I PURCAHSED AT CVS / PHARMACY I GET CBS AND ABC STATIONS GREAT BUT I CANT GET NBC??????? PLEASE ADVISE OF THIS ISSUE
NBC antena broadcasting signal is weak and it sit in pretty low ranges on the mountains tops call mountain Wilson.The broadcasting antena is weak and ur receiving antena is weak too.Tries websites like Amazon.com Ebay.com to buy a Digital antena and used it,will boot up ur tv antena receiving signal stronger and longer ranges.Than.U will able to get the NBC tv channel.
Dec 03, 2010 | Televison & Video
I have a 13' Orion tv, model #TV1326BW with rabbit ear antenna. I have connected everything correctly to the converter box for digital signals. I can pick up all stations except the local CBS affliciate....
I have the same TV & cannot get into the TV menu to program the cable... it was bought secondhand without the original remote. There are no buttons anywhere on the TV itself to bring up the menu & the universal remote's menu option doesn't do it, either... how do I set the channels?
Aug 04, 2009 | Televison & Video
Can't recorder digital broadcast
Hi,if your vcr is an analog machine then you will not get a signal.If you have a seperate digital box then you can connect this via a scart lead to av2 on the vcr.Best thing though is to buy a digital dvd recorder.hope this is of some help.jamie
Mar 02, 2009 | Zenith XBV443 DVD Player/VCR
VCR HOOKUP PROBLEM
you will need to hook your signal to the converter box then into your vcr and then into your TV. Now if your vcr has signal out then you will not have any problems hooking your tv up to the vcr. You may have to use the audio out to get the right sound with your tv.
Feb 10, 2009 | Hitachi Televison & Video
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
I have a AKAI CFTD 2085 model tv. Is it digital or do I need a converter box?
If connected to cable or satellite your tv will work after digital conversion occurs. If using an antenna, look up a local TV station to see if they're already broadcasting in digital. Most are. Enter that DIGITAL channel # using your remote. If you get a picture, you don't need a converter box.
Dec 04, 2008 | Akai CFTD2085V 20" TV/VCR/DVD
Don't get ABC or NBC local channels anymore
ATSC tuners ("D/A converters") pick up signals off the air just like old school television. It sounds like you are just not getting a signal of sufficient strength. A weak analog signal looks like a "snowy" picture, which most of us are used to. But, the new digital channels quickly go from a perfect picture to none at all. It's basically all-or-nothing.
Try attaching an antenna to your converter. I know you can buy a new antenna from your local big box electronics store which is labeled "Terrestrial HDTV" or something, but that really doesn't mean anything. You can use any old TV antenna. Even a quality FM antenna (with an F-Pin coax connection) may work just fine.
When setting up the antenna, keep in mind that different channels are transmitted from different towers, in different locations with different strengths. Move the antenna placement and position around (just like grandpa had to do). You may have to make a compromise to get the best signal for your favorite channels.
May 15, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
242 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
