Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intex automatic salt water system died can I chlorinate the salt water.
    President:
  • Intex Master
  • 1,378 Answers
Yes you can. Liquid would mimic your salt water generator in that it will slowly raise your pH over time. Switching to tablets would do the opposite to pH.
Posted on Jun 16, 2009
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
Just purchased and installed Intex salt water system. It shows low flow and now, after 5 days of installment, the water is completely green (expecting Swam Thing to come out!) I need your guidance to...
Seems like you may not have the pump and the salt chlorinator in sync... If your water is dark green and not a big pool, you may want to drain and refill, if you have a large pool, you may want to shock and then try the following...
1.Make sure you have added the correct amount of salt...
2.Set your timer for your pump for 12 hrs.
3.Wait 15 minutes and then turn on your intex salt water system..
4.Set you hrs of operation on your salt water system for 10 to 11 hrs...
5.After running the system for 3 days, check your chlorine level..
If water clears and chlorine level is high, adjust the time.. You will have to re-sync the pump and chlorinator.. If the pump turns off before the chlorinator finishes it's cycle, you will get a "LOW FLOW" alarm..
I hope this helps and good luck.. Please rate and comment on the information provided.
Jul 26, 2011 | Intex Automatic Salt Water System for ...
Where do i add salt to my intex automatic salt water system
Ad salt right in the pool water. Filter and brush around to disolve. Do not try to generate chlorine for 12 hours or so.
Make sure your salt content is as close to 3000ppm as possible
Jun 16, 2011 | Intex Automatic Salt Water System for ...
Why would our salt water system not be producing chlorine? Intex it was installed less than a month ago. to a very green pool we have put in chemicals and gotten it pretty well cleaned but its still is...
first crack union at return see if chlorine present with test strip if ok then pool needs super chlorination its eating up your chlorine if no chlorine at return have salt level checked if ok check sensor and cell if unit is working must keep balanced unit will only maintain
Dec 25, 2017 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator I added a higher flow pump and chlorine levels seem low no matter how many hours I run the chlorinator
your pump has nothing to do with chlorine generation.
You need to get a salt test kit that reads in #'s not colors.
Now get your salt to 3000ppm or as close to it as you can.
The amount of salt reccomended in the manual is just a starting point
any lower than 2800 and you will not produce enough sanitizer and over 3600 and your pool can go cloudy, taste bad, and rust metal parts
Jun 28, 2010 | Intex Automatic Salt Water System for ...
Can chlorine be added to the saltwater intex system if salt has already been added
it can be added and also regular house hold bleach
why would you need more chlorine?
If you are needing more then something is wrong
If your salt content is not 3000ppm or more but not above 3800ppm then you are not going to be able to generate enough chlorine
Also you should be using a stabilizer that help hold chlorine content
Jun 19, 2010 | Intex Automatic Salt Water System for ...
Just added an Intex salt water Gernerator to my existing above ground pool. Water is green, can I add chlorine shock to speed up the process. And Ph is low. Can i add PH increaser or should I just wait and...
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit. Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
Apr 18, 2010 | Intex Automatic Salt Water System for ...
Our pool water is yellow and think it is because low chlorine
Add more salt and no salt strips only chlorine
There is also some chlorine called super chlorine that would work better
Jun 01, 2009 | Intex Automatic Salt Water System for ...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
324 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
