Question about Olympia OL2420 Cordless Expansion Handset
Need to knoww how to change volume to hear phone conversation
Cant see the screen need to be talked through problem
0 characters
1 Points
Volume on ring and talk too low How can I boost the volume
perhaps getting him a hearing aid would be quicker way to fix problem . most phones have limited volume .
Feb 22, 2016 | Phones
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
How do i increase the volume ob the receiver,not the ringer volume ,voice while speaking as i cant hear the other party loud enough
When you are talking on the phone (or listening to a dial tone), the volume control works to control the volume of the receiver. When the phone is not being used, the volume control is used to control the volume of the ringer.
Feb 24, 2010 | Uniden Cordless Phone
Hard to hear on one of the handsets
we have the same phones, the volume can be adjusted using the key pad but only slightly the hearing overall with this phone is not so great you end up straining half the time to hear the conversation
Sep 04, 2009 | Panasonic KX-TGA101S Cordless Handset
Kepad beeping while using MagicJack
I have the same problem with the key pad beep during telephone
conversations and I hace a Uniden 5.8ghz phone.
So its not just panasonic 5.8 ghz phones that do the beeping.
Jul 11, 2009 | Panasonic Phones
How do I turn up the volume to hear someone talking?
press the arrow up on the round key while you are talking
May 14, 2009 | Panasonic KX-TG1033S Cordless Phone
When people phone me i cant hear them though they can hear me and all volume levels set to high
you have to reset your phone or replace the earpiece speaker.
Apr 29, 2009 | Phones
Using 2 phones at same time.
most units can only "talk" with one unit at a time, because they are using a set freq. for both sides of the conversation. (think walkie-talkies of children) you can't talk and hear at the same time!
Mar 08, 2009 | Uniden Cordless Phone
We can't have two people at our house talk.
There is no way to have 2 phones in use at the same time- unlike different models of phones you may have had-like a ge in the kitchen and rca in family room-they do not conflict the signal-these are all on the same channel and will not share the connection from the base.
Sep 19, 2007 | GE 25951EE2 Phone
Volume Control?
When in conversation press the up/down arrow button in top centre just below the screen
Jan 31, 2007 | British Telecom Freestyle 2200 Trio...
Olympia OL2420 Cordless Expansion Handset Logo
18 people viewed this question
Top Olympia Phones Experts
Are you an Olympia Phone Expert? Answer questions, earn points and help others
