Question about RTO PasLode 900420 Impulse Framing Nailer
Will onlyshoot one nail and quits - RTO PasLode 900420 Impulse Framing Nailer
    Sniper:
  • 79 Answers
First, make sure you gas is not expired, it has a date on it. Next, Make sure your green light comes on. Does the fan come on when you press it down? Take off the back cover with the allen wrench and two phillips head screws on the sides. Pull it out, being very careful and make sure when you put it back the wires are tucked in there place again. There is an o-ring under the fan that may need replacing causing the vacuum to not work.Also, make sure the little spark plug is clean of all carbon residue. Clean with some WD40 or ether. Worst case scenario fan motor or spark plug. You can find parts for these things. Lemme know. Please rate me
Posted on Jun 18, 2009
I have propulse 2 inch Brad Nailer. Model 57265001. when i press switch just air blow out but no nail or nailing
1. Does it have any nails in it? A) add nails
2. Often when you get down to the last few nails it will quit working. A) add more nails, you may have to discard the remaining nail or three before adding more nails.
3. You may have reached the end of a group of nails and the last nail or 2 are jamed up in the end of the nailer. A) Need to open end of nailer and remove jamed nails. Don't forget to disconnect nailer from compressor first.
4. Other options are not enough air pressure, or the gun is damaged and needs repaired or replaced.
Good luck.
Aug 02, 2016 | Air Tools & Compressors
I've got a nail gun campbellnausfield and can't get it to shoot a nail
is the hammer sticking out where the nail comes out . if so it will never shoot simply press it back in with air turned off then it should work again. they do this quite often when putting nail into soft wood perhaps you are using too much air pressure too
Aug 30, 2015 | Tools & Hardware - Others
How do I paint my finger nails perfectly?
use cellotape or inch tape wrap around nails and color the nails and peel off simple and cheap
Feb 23, 2015 | Health & Beauty
Max superframer
check the capacity of the air supply as the compressor may not be able to oversupply the usage required. next check the lubrication requirements for extensive operation
May 17, 2013 | Tools & Hardware - Others
Roof coil nails any diffrence
Internally they are the same, however the rnd has a semi clear cover to see the coil nails in the cannister (could be other differences but use same nail). There is a difference between brands of nails. Check with local code for required length and type (galvanized , stainless etc). Make sure that the wire that binds the nails together is not too strong and stiff. Some coils have soft copper that works quite nicely and others use a stiff steel wire that tends to pull at the coil and leaves a stiff piece of wire in front of the first nail preventing good alignment to driver. If you are going to depend on your nailer for daily work, order and have in stock upper bumper and cylinder seal. These parts will fail quite quickly. Other parts tend to hold up pretty well. Good luck
May 31, 2012 | Ridgid ZRR175RND FactoryReconditioned 134"...
I have roughed up the nail....applied bond aid once (even tried twice) but nails tend to get soft and can be easily peeled off. What can I do to avoid this?
Hello Dear
Soften nail is due to the soakness. Stop soaking your nails in the gel.
If they get soft then apply Almond Oil and Olive oil mixture and massage on your nail for 5 mins then after half hour Wash your hand and apply any misturizing lotion on to your hand.
Breaking or softing of the nail will quit after a week.
Aviod Soaking your hands for more than 5 mins.
Avoid Dish washing. if its necessory then wear gloves.
Regards
( Please rate the answer)
Feb 15, 2011 | Opi Axxium Gel Nail Soak off Thick Gel...
Quit firing nails motor comes on but nothing happens when pulling trigger
I am assuming that you have changed the gas cylinder. Make sure you have the exact correct cylinder, because there are some that look like they fit, but don't quite seal. This unit requires battery charged for ignition and induction fan. And it requires fuel to drive the nail,.
Oct 16, 2010 | RTO PasLode 900420 Impulse Framing Nailer
GT90CH fires but no nail after twenty shots.
a bit of air tool oil might help, make sure you are not getting condensation in the line, otherwise you may have to dissassemble to clean
Jul 27, 2010 | Senco GT90 Clipped Head Gas Framing Nailer
Fires 2 & 3 nails every so often.
Most all nail guns can be converted to single fire, however, usually parts must be changed. Some brands have two positions on the trigger, others have a button position near the trigger to accomplish same. Check with dealer or email your gun model # and I will explain your to fix. For now you can replace the spring on the safety with one slightly stiffer. Also try nailing with trigger depressed and quickly bump the gun to fire, this method usually works better than placing the gun in position then firing. Good luck with your repair.
Jun 24, 2010 | Hitachi 3 - 1/2" Full Roundhead Framing...
N80 suddenly quit working
There is a nail stuck inthe grove where the nail comes out. There are 4 allen bolts on the front of the nailer.remove them and you can remove the bent nail. Put it back together and your ready to go.
Mar 11, 2009 | Stanley Bostitch N80s Nailer -rebuild...
RTO PasLode 900420 Impulse Framing Nailer  Logo
324 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
