Question about Dryers
House lighting is dim ,when dryer turn on
Wiring;from panel to dryer AWG8,
electrical panel 200A
  • 174 Answers
Sounds like the dryer is pulling too many amps, should check that out
Posted on Jun 16, 2009
Light is dim
Why do my lights in my house dim when I use the Microwave or dryer ...
https://answers.yahoo.com/question/index?qid...
Jan 16, 2010 - I dont run a lot electricity. It seems that if I run something like themicrowave any lights that are on dim. Is something wrong here? I dont see why ... Light on microwave too dim to read -- can it be fixed? ' Yahoo ...
May 11, 2014
My lights dim when I turn on a powerful electrical device ...
Dec 31, 2007
Why causes all the lights to dim and then brighten repeatedly ...
Dec 28, 2006
More results from answers.yahoo.com
Dimming Microwave Light - Breville Support
brevilleusasupport.com/bmo734xl/dimming-microwave-light/
Apr 10, 2014 - Occasionally, when using power settings that are lower then the normal 100% cooking power, the light inside the microwave cavity may dim.
Dec 21, 2015 | Microwave Ovens
Why do lights flicker
An electric water heater will draw a lot of electricity. Your house may not be wired well, and when the heater kicks on, your lights will dim some. If your house is over 25 years old, it's likely normal.
Nov 02, 2014 | Rheem RTE 27 Tankless Electric Water...
Compressor keeps turning on and off, I can hear it and it dims the lights showing an increase in power draw, it will blow the main circuit breaker to the house. Therefore it does not run enough to remove...
If when it's running it dims the lights in the room or entire house, The circuit breaker for the receptacle it's plugged into, is not a high enough amperage to carry the dehumidifier and whatever other electrical appliances that are on the same circuit. OR if your house is hold enough (1970's era), it may have aluminum wiring and its overheating .
If it's blowing the Main Circuit Breaker for the entire house and not just the circuit breaker for the receptacle it's plugged into, Stop using the dehumidifier immediately!!! Have an certified electrician check your home's circuit breaker panel and wiring. This could be a dangerous situation.
Mar 01, 2011 | Maytag M3DH30B2A Dehumidifier
Control panel not working
If you have power going into the control but it does not illuminate or respond the control will need to be replaced. Here is a link that should help http://appliancehelponline.com/dryerconsole.html These boards are very sensitive to power surges and are not repairable, they must be replaced.
Jul 27, 2010 | Frigidaire FEQ332E Electric Dryer
We just moved into a new house, and whenever I use
It sounds like it could be one of the following issues:
1. Bad wiring to the bathroom receptacle - this should be a GFCI outlet.
2. There is an overload somewhere on the same circuit - try the dryer with nothing else turned on.
3. The hair dryer may be bad or have a bad cord, plug, etc. Hair dryers can also become plugged (the air inlet screen) and overheat.
4. There could be loose or other bad wiring somewhere in the circuit.
If you are not familiar with working with electricity, it would be best to call a qualified electrician. They are the pros and can correct the problem.
May 20, 2010 | Kitchen Appliances - Others
White knight dryer wk767 (Crosslee) blows fuse when turned on
Probably a problem with the heater element (if mineral insulated metal sheath type), or fluff on wire heater coils if that kind. This is behind the back cover.
Feb 27, 2010 | Dryers
GE frontloader electric dryer is causing an electrical surge
Check the connectors and lugs on the powercord ,wire and breaker box
Apr 07, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Won't power on
U have only 120 vac, need 240 vac. Turn the 30 amp breakers hard to off then back on. Should do the trick
Apr 29, 2008 | Kenmore Elite HE4 Electric Dryer
Measure voltagebetween COM terminal of relay RL2 and neutral.
If 0 volts - defective house power supply or broken wire between terminal block and relay. If 120volts - replace control board
Jan 02, 2008 | Frigidaire GLEQ2152ES Electric Dryer
PS Comes up on Display
has a bad motor start winding thats why your lights dim change motor
Dec 03, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
Marvin
Marvin
