Question about Microsoft Xbox 360 Console
E68 My Xbox just started the exact same thing today. Does anyone have a solution?
  • EricksGotFix May 11, 2010
    While the 360 is off remove EVERYTHING connected to it. Now plug in ONLY the power and A/V cables. Turn it on and see if any errors occur. Please respond for further help.
    Problem Solver:
  • 7 Answers
When you get a message like that stand the 360 up or lay it down which ever one is opposite of your current placement that will fix it if it does it again repeat it may take a few times but it works
Posted on Jun 18, 2009
Fix E68 error code on xbox360 slim
Hi there elaine try this walk though i have put the link in here for you to to step by step instructions it sounds like the hard drive is gone..
http://www.wikihow.com/Fix-an-Xbox-360-Error-E68
Cheers Nikki
Nov 13, 2011 | Video Game Consoles & Games
Gives me an error E 68 what is that? New xbox is only 10 months old.
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem, much like all of the problems in the "e6x" family of error codes on the Xbox 360 platform. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
May 21, 2011 | Video Game Consoles & Games
E68
The e68 error can mean a bunch of different things on an Xbox 360.
I have personally had this error and I had to turn the unit off, unplug it, disconnect the HDD, reconnect the HDD, plug it back in and power it on.
Fixed it like a champ.
Here's some useful websites that contain information on the e68 error:
http://www.ehow.com/how_5121542_fix-xbox-error.html
Thanks and please rate if this helps you!
Mar 29, 2011 | Video Game Consoles & Games
I was watching net flicks and my xbox rebooted and flashed a red ring (bottom right) and it said E68. i shut it off and started it up again and works<did that twice<the unit was alittle hot...
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
To fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft, as the e68 is generally believed to be related only to your console's hard drive/HDD.
Hope this helps.
Mar 06, 2011 | Microsoft Xbox 360 Console
Do i need a new hard drive if the one i have gives me the e68 error when it it in the xbox when it isn't in it turns on no red light but when i plug it back in i gives me it again. thank you.
Hello! no need to worry! the E68 error code is one of the more simple things to fix. most of the time it's just simply a hardware fluke. Attached you will find detailed instructions on how to successfully restore your hard drive and eliminate the e68 error code. If unfortunately, you must purchase a new hard drive, you can find reasonably priced drives at your local electronics or computer store.
If the steps listed in the link fail, the contact information for Microsoft is included as well. Good Luck!!
How to Fix The E68 Error Code
Dec 29, 2010 | Microsoft Xbox 360 Console
How i fix on my xbox 360 e68 problem?
hi, that error code usually relates to either a problem with the hard drive or a problem with the fans or a problem with some external source such as extra fans or other devices connected to your xbox, so try playing with no hard drive attatched and if it still dont work you know the hard drive is working as it should, if it works without the hd then it will need formatting or getting a new drive.
if it still dont work and you have extra things plugged into xbox unplug them and see if it works, if nothing works then the problem could relate to the wrong voltage getting to the fans.
here is the exact e68 error code:
E68: Hard Drive Error - Hard drive not DMA configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. Also this can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 07, 2010 | Microsoft Xbox 360 Console
E 68 error code.
Step one to fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft
if it is the hdd there are guides on the net on how to fix it
Aug 23, 2010 | Microsoft Xbox 360 Console
What is e68 on a xbox
What you need to do is
1. rmeove the hard drive from unit then turn it on
Foolwo this link and what is is and how to fix the issue
http://ezinearticles.com/?Xbox-Error-E68---Xbox-360-E68-Error-Repair-Tips&id=2340222
thanks and hope this information does help please do leave your feedback and ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 11, 2010 | Microsoft Xbox 360 Console
Error code E68 unknow reason on xbox 360
fallout games are always known to make game consles mess up just send it off ad get a new one
May 03, 2009 | Microsoft Xbox 360 Console
E68 error
Sorry to say you got a bad hard  drive. Call MS or take the system back to walmart for a new 1 because I dont think they will give you a new hard drive. Who knows they might, call and ask!
Oct 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
