Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony wega keeps cutting off then coming back .
It ran fine, then this morning it started turning off then a few seconds later it would come back on, the green light blinks when it does it. this tv is only a couple of years old.
  • 35 Answers
A couple of years old can be a long time:
has the TV been on 24\7
It's the amount of hours that matters..
electrolytic capacitors typically last 3000 to 5000 hours....
Special "long life" caps last close to 7000
but the caps in most consumer electronics, even broadcast equipment 3-5K hours.
Posted on Jun 16, 2009
Broksonic Flat Panel TV, tried to turn back on TV and Green LED light is blinking and screen pops up a few sec with white and colored lines and the turns off
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 21, 2014 | Broksonic Televison & Video
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Philips 42FD9954
Hey I have the same problem with my 42fd9954/69s. The best solution that I found that works everytime is I have taken the back off my plasma hung it on the wall. Then when I need to turn it on I it starts clicking, so I get my $10 room heater and blow some hot air down the back of the tv from the top and 30 secs later the tv will turn on.
Too easy. Bit dodgy, but I am a uni student!
Nov 08, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Maxent 50" plasma problem
We seem to have had the same problem. Green light keeps blinking but will not turn set on or off. I unplugged the set for a few minutes, plugged back in and works fine but will happen from time to time for no reason.
Sep 12, 2007 | Maxent MX-50X1 50 in. Plasma Television
JVC PD-42WV74 tv turned itself off and unable to turn it back on. Green light blinks on receiver and TV.
Unplug the TV set, after a few minutes, plug it back again. If you are lucky, the TV will be okay!
May 07, 2007 | JVC PD-42WV74 42 in. Plasma EDTV
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
197 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
