The machine does not stop to fill up water
Already change the water sensor
    Sergeant:
  • 249 Answers
Did you change the blue water fill valve on the back that your hose's connect too? i had a problem with the hose coming off up inside the control panel too
Posted on Jun 16, 2009
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
My whirlpool cabrio7600 top load washer starts up filling with water an doesnt stop filling.
Hi.
If the water inlet is faulty the water flow will only stop if you turn the wall tap off...
If the fault is in the machine the inlet will stop when the machine or the electricity is turned off.
If the water flow stops when electricity is halted it indicates that the inlet is functioning properly. There are a number of things which can cause the inlet to not turn off, such as the water level sensor is faulty or blocked. It could even be that the motor controller is faulty.
Unless it is a simple inlet change I recommend that you let a technician look at your machine.
Good luck,
Nomess
Mar 03, 2015 | Whirlpool Washing Machines
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
Whirlpool front load washer will not fill with cold water
Sounds like your Valve is either inoperative, you have a Clog in the COLD (there is a small screened filter where the hoses connect or your board has went bad..
Jul 20, 2014 | Whirlpool Washing Machines
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
Already took off pump & cleared out $12 in change but still will not pump all water out or spin out. can hear pump running but think the damage has already been done. would it be pump or pressure...
If the washing machine won't fill up, make sure that the water supply valves are turned on. Next, make sure there are no kinks in the supply hoses that run from the supply valves to the washing machine. If nothing is obstructing the hoses, you may have another controls issue.
Several of the washing machine controls are also responsible for the washing machine not draining, continuing to fill or filling too slowly. If the washer doesn't want to drain or stop filling, the issue could be the pressure switch. When water enters the machine, water also fills a tube in the pressure switch. When the air pressure reaches a certain point, it triggers a switch that will stop the machine from filling. Locate this pressure switch on your machine and look for damage. If you have a multimeter, use it to find any electrical issues. If there is no reading, the pressure switch needs to be replaced.
Read more: Tips to Repair a Washing Machine ' eHow.com http://www.ehow.com/way_5435622_tips-repair-washing-machine.html#ixzz1C6BhALK0
Jan 25, 2011 | Frigidaire GLTF2940ES Front Load Washer
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
I have a admiral washing machine that will not stop filling. i changed the water valve and that was not the problem. any other suggestions.
There is a water level sensor that controls the water valve. It should be shown on the schematic, trace the wire from the water valve to the level sensor
Jun 10, 2009 | Washing Machines
THE WM DOESNT STOP FILLING UP WATER
It sounds like your water level switch is bad and needs to be replaced. The inlet valve opens and starts filling, and timer operation is suspended until the water level switch operates.
Jan 10, 2009 | Kenmore 24902 Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
