Question about Whirlpool Duet GHW9150P Front Load Washer
The washer will not power up. there is no "click" in the CCU when plugged in. where do I get a CCU?
    President:
  • 1,865 Answers
Www.apwagner.com Enter your model number, and it will show you all the parts available
Posted on Jun 16, 2009
Kenmore elite he3t front load washer has no power. Replaced ccu, worked for a few minutes then stopped. Unable to power up
I would guess you have a short in the machine somewhere and likely have fried the new CCU also. If you want to and have the ability, you can track down the short and fix that. Then you will probably have to purchase another CCU before it will run. Wish I had better news. Good luck.
Jun 22, 2016 | Kenmore Washing Machines
F01 CODE ON WHIRLPOOL MODEL# WFW8500SR00 FRONTLOAD DUET SPORT HT, ALLREADY CHANGED THE PUMP MOTOR
ERROR CODE F01
The pump driver fails to activate/One of the main relays is not working properly/
A communication error between the Central Control Unit (CCU) and the EEPROM
onboard the CCU occurred.
Check for loose power outlet. A loose power plug in the wall can create
line noise and issues.
- Check if washer is on a dedicated circuit. Other devices on same circuit
can create line noise and cause this issue.
- Unplug washer or disconnect power.
- Make sure that wire harness connections from the CCU are not broken or with wires
detached, and that connector internal pins are visible.
- Make sure all green wires (ground harness system) are not broken or detached.
- Make sure the two ground switches are pressed correctly by the toe and rear panels.
- Make sure all connectors are fully seated.
- Plug in washer or reconnect power.
- Check for power going to Central Control Unit (CCU) by listening for a click in the
CCU when unit is plugged in washer or when reconnecting power.
If no click is heard, replace the CCU. Here is the part to order.
Oct 10, 2013 | Washing Machines
F 01 fault code on front load washer
ERROR CODE F01
- Verify unit operation by performing the Diagnostic Test.
- After the diagnostic test has finished, unplug washer or disconnect power
and wait for 15 seconds.
The CCU is located under the top panel which you already removed. Here is the part to order.
Nov 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
07f error code... duet washer W9150
Tech sheet on this model:
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will
be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/proceedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
F-06 Drive motor Tachometer error
Possible causes/proceedure:
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
F-07 Motor control unit error
2. Check wire harness connections between the drive motor and
3. Plug in washer or reconnect power.
4. Check the MCU by looking for operations of the drive motor.
5. Check the drive motor for powered rotations.
F-09 Overflow Condition
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. the pressure switch for proper operation.
F10 Motor control unit heat sink thermal trip
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
3. Check wire harness connections to the MCU, the motor,
4. Check the drive system for any worn or failed components.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
2. Check wire harness connections to the MCU, the motor, and
3. Check the drive system for any worn or failed components.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
F13 Dispenser circuit error
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
4. Check dispenser motor for powered rotations.
F14 The dreaded EEPROM error
The Central Control Unit (CCU) receives its data from an EEPROM
onboard the CCU. If there is an error reading this data it will cause this
error. Possible causes/proceedure:
¦ A power glitch may cause this error.
1. Unplug washer or disconnect power for two minutes.
2. Verify CCU operation by running a Diagnostic test or any
cycle.
F15 Motor control unit error
If the MCU detects multiple resets or errors during a wash cycle it will
go into this error mode. Possible causes/proceedure:
3. Check drive belt.
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
touch-pad/LED assembly and Central Control Unit (CCU).
F du Door unlock error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to
unlock the door 6 times before displaying the error code.
¦ Door lock mechanism is broken.
¦ Door switch/lock unit failure.
1. Check door switch/lock unit for foreign objects.
3. Check wire harness connections to the door switch/lock
unit and Central Control Unit (CCU).
NOTE: The door switch/lock unit can be manually unlocked. See
"Manually Unlocking The Door Lock System".
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
¦ Door lock mechanism is broken or removed from door.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
or kinked.
6. Check drain pump.
7. Check the pressure switch.
cycle.
Tech sheet link:
https://servicematters.com/secured/docs/wiring/Tech%20Sheet%20-%208182277.pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine will not turn on. yes i checked the outlet
Make sure that the outlet is working even though the breaker is okay. Plug a small lamp or appliance into the washer outlet to verify that it is working.
If the outlet apparently has power the plug the washer back in and listen carefully for a click from the CCU (Central Control Unit or main control board shown in the first image below). If you do not hear a click then I recommend that you unplug the washer and remove the top panel (shown in the first image below). Check the wiring harness connections on the control board. I provided a wiring diagram in the second image that shows the path of power to the CCU. If you have a volt/ohm meter and the technical expertise, you can check the continuity of the power supply to the control board (wires traced in red and green on wiring diagram below). If the CCU is apparently getting power but does not click shortly after it is plugged in then it will need to be replaced.
You could also have a failed user interface touchpad assembly that would prevent the washer from powering up.
These tips may help you determine the cause of this washer failure.
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
First machine would come on, do nothing, then go off. Now it does nothing and the door will not even open. Any ideas?
1. Check that the unit is plugged into a working outlet and for blown fuses. 2. Check for power going to Central Control Unit (CCU) by listening for a click in the CCU when unit is plugged in. If no click, replace CCU. 3. Unplug washer or disconnect power. 4. Check continuity of line cord and line filter. 5. Check harness connections to CCU. 6. Plug in washer or reconnect power. 7. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding.
Nov 28, 2010 | Kenmore HE2 Plus Front Load Washer
"F-01 error after pushing start button
Hi, the technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
Oct 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No power
not sure about the CCU. I'm not familiar with this washer. But, when using a meter....an ohmeter is used for testing continuity of a wire. if you can touch each end of the wire with the meter probes, you should observe a low resistance (low number). If the wire is broken you would see no change on the meter (infinite ohms). You would, of course, have the cord unplugged to prevent shocking yourself whenever you have the covers off of the machine.
Aug 24, 2008 | Kenmore 46462 Front Load Washer
F33 code
1 Unplug washer /disconnect power
2 Check wire harness connections to the pump & Central Control Unit (CCU)
3 Plug in washer or reconnect power
4 Verify CCU operation with Diagnostic Test or any cycle
This occurs when the connection between pump & CCU is lost.
Apr 18, 2008 | Whirlpool Washing Machines
HE3 washer wont power up
WON'T POWER UP. (Touch-pads do not respond when pressed)
Check the line voltage and for blown fuses.
Check for voltage going to Central Control Unit ( CCU) by listening for a click in the CCU when unit is plugged in
lf no click
replaceCCU.
Unplug the unitb eforec ontinuing.
Checkc ontinuitoy f linec orda ndl inef ilter.
Checkh arnessc onnectiontso CCU.
Checkt ouch-pad/LEaDs semb
Feb 23, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
