Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Does this thermostat have a delayed start setting?
Does the Honeywell RTH2308 thermostat have a delayed start setting? Can I adjust it? If so, how?
    Sergeant:
  • 340 Answers
You will have to have the installer manual and go into the con fig settings to change Honeywell.com
Posted on Jun 17, 2009
Honeywell RTH2308 batteries were dead so replaced and now furnace will not start
Replacement batteries may have been installed incorrectly. We've all done that, and on a Honeywell too. Also it is possible replacement batteries are no good. We've all done that as well.
Apr 19, 2018 | Honeywell Heating & Cooling
How do I set thermostat to come on after burner starts
You are asking a question that makes no sense mechanically, if you mean the fan, it is controlled by the temperature delay or a time delay built into the furnace.
Mar 01, 2015 | Honeywell Electronic Programmable...
Trouble shoot rth2308
on pages 26 and 27 of the manual it clearly states that the unit has a safety device installed in at the doesn't allow the heat and the air to be turned on one right behind the otherif you are testing out both air and heat expect about a 15 minute delay between both of them that is to protect your system just leave the unit alone you don't update by itself and it'll start working correctly in about an hour
Feb 23, 2015 | Honeywell Programmable Thermostat Heater
All electric new home. Bought honeywell programable thermostat RTH2308. A/C works but heat will not turn on. This model # is not on their web site.
check to make sure there is a jumper wire on the subase between "rc" and "rh". these designations stand for red/cooling and red/heating.they are used independently if the system has a separate control transformer for heating and a separate one for cooling. they need to be jumpered when one transformer is used to control both modes. your fan "on" switch won't work the fan continuosly if there is no connection to the "r/c" trminal.
on the back of the thermostat there should be a switch you need to select for gas or electric heat. or there are small micro switches that need to be set for your particular application.check your installation papers for details.
these thermostats usually cover a wide range of applications and need to be selected.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
I have a TH8000 Vision Pro. It is controling a
Whats' so hard is the Honeywell thermostat has a built in 1@ differential. It is not adjustable.
You might ask your installer about a time delay relay installed in the furnace to break the thermostat heat wire (usually white wire).
Most time delay relays are 90 seconds. But that might be enough to reduce the furnace cycling.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Honeywell heating system
go to the main power box and find the either breaker or fuse that runs the system and turn it off
Dec 25, 2008 | Honeywell Programmable Thermostat Heater
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
393 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
