Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Camera says SD Card is locked but card is open;
Although the camera says the SD Card is locked, the slide on the card is in the open position. Camera had performed well for two seasons with no problems. If the internal switch for the SD Card is locked and doesn't recognize the open card, how can this be repaired???
  • Moultrie Master
  • 4,738 Answers
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on Jul 11, 2009
Camera saying memory card locked slide lock write psition
The Nikon N75 is a film camera. It doesn't use a memory card at all.
If you're referring to some other digital camera that does use an SD/SDHC card, look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 21, 2013 | Nikon Photography
Micro sd adapter i keeps in camera it is shows card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 18, 2013 | Canon Cameras
Card locked
If your camera uses a SD memory card then -
SD and Mini SD memory cards SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Feb 02, 2013 | Canon PowerShot SD600 Digital Camera
Camera says card locked
Aug 25, 2012 | DXG Technology DXG-518 Digital Camera
The card is locked so the camera doesn't work. how do I unlock it?
SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.
May 12, 2012 | Casio EXILIM EX-Z1000 Digital Camera
Memory card locked appears as soon as i power on the camera
Mar 12, 2012 | Sony Cameras
My Vivitar ViviCam 5024 locks any SD Card I Insert In It How do I Stop This My Wedding is in two hours.
Are you are saying the act of inserting the SD card into the camera is pushing the slide lock on the edge of the card into the "lock" position? Try moving the slide with a fingernail. If it slides "easily" it is probably a defective package although it may still accept data. Have you used it successfully before? In this camera? In another SD device? If it slides "loosely" you can try putting a small piece of VERY thin tape (not duct or masking tape) tightly around the card, being careful not to cover any of the contacts. If the slide doesn't move, go ahead and shoot. You may have trouble removing it later but at least you have your pics. If the slot still pushes the tab into the lock position, I hope you have another card you can use. Good luck!
Jan 30, 2011 | Vivitar ViviCam 5024 Digital Camera
When I open my camera it shows `card locked`
You didn't specify the make and model of your camera, so I'm going to assume it uses SD cards.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jan 15, 2011 | Cameras
How to open card lock in canon camera
Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 14, 2011 | Cameras
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
287 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
