Question about Frigidaire Refrigerators
Frigidaire Gallery model - FRS26ZTH side by side. I have water leaking inside in the freezer compartment out of the back panel area down to the bottom and out the front door.
SOURCE: Freezer compartment leaking water and icing up inside
does anyone know someone who can fix this in the newcastle on tyne area
beepbapbop
Posted on Jan 31, 2008
mgprice
  • 744 Answers
SOURCE: Kenmore bottom freezer refrigerate leaks
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Posted on Aug 14, 2009
Testimonial: "Greatly appreciate yor help, Mike. Found screws to remove back panel, but the ice maker is plugged into a hole in panel can this be unplugged?"
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
ryeisenman
  • 9 Answers
SOURCE: cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Posted on Dec 13, 2008
SOURCE: Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Posted on Dec 31, 2008
Frigidaire refrigerator side by side model FRS26ZTH water on floor of freezer
pull it out from wall there is a tube that runs down to drip pan under neath also check door seal by closing door and sliding acard between seal and unit if loose or gap it will make unit sweat
Jul 13, 2012 | Frigidaire Refrigerators
Freezer is dripping water into the bottom of the freezer and causing sheets of ice to build up in the bottom of the freezer compartment. It is a Frigidaire Gallery side by side.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 13, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frs26zth side by side refrigerator is leaking water from under the freezer side - the water line and the ice maker are not hooked up. So what could be the problem
Hello there:- I presurme the water is leaking out underneath the drawer on the freezer compartment. Since there is no other prosibility where the water come from . So it must be the defrost water not running down the drain tube to the drain pan through the drain hole on the freezer side because it is blocked . Clean out this drain pan hole and the drain tube see you can sort out the problem. God bless .
Oct 06, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire gallery pro series model frs26zsh water leaks out somewhere goes into backside of freezer eventually goes down to underside of bottom basket and freezes
Mor than likely you have a clogged defrost drain. Drain is located at the bottom of freezer compartment behind the back panel. You will have to remove the panel and blow out (or vacuum) the drain hole. Hope this helps
Jul 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have water leaking out the back of the freezer side of my side
Pull the fridge away from the wall and check where the water line enters the fridge for the ice maker. If there is a fitting there, make sure that it is tight or the clamp is secure. If it looks cracked or split in any way, remove it and replace it with new hose.
Hope this helps,
Jeff
Jul 08, 2009 | Frigidaire GLRS264ZA Side by Side...
Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
May 27, 2009 | Frigidaire 26.0 cu. ft. Side-By-Side...
Fridgidaire Gallery Series Side by Side Refridgerator
"jennycub" sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. very common problem( easy to detect. water on the floor of freezer compartment) as far as the other posting by" humblerumble", ive seen where the drain tube under the refig has pushed a hole into the drain pan under the refrig, in which case it will only leak after a defrost cycle, with the kickplate removed grab a flashlight and look under the unit for the drain pan as you pur water into the back of the freezer sect to trace water flow
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
739 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
