Ir, I have a cannon ir3300 photocopier...Its print clarity and neatness are fine and its didn't shows an error but the problem is the print coming out is in a wave shape.. lines are coming out like a sine wave.. can u describe the reason of the problem?...how can i solve this?..
True multi-functionality means you get more for your money in
less space with the iR3300 black and white office photocopier. Handling
the work of many in one compact solution, the iR3300 provides a
cost-effective solution to your printing needs. Features of the iR3300:
Provides copying, printing, scanning and faxing all in one unit.
Hello
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
otherwise
This code also for Heater Coil Fault.
Replace the Fixing Element Coil.
Hope this helps
1) install Network ScanGear software from canon officiall site, search under ir 3300, and among all drivers there is scangear too. 2) when you install scangear, open it and press discover button, but the light scan on copier must be on, and set on ONLINE. 3) Then over eg. word2003 go to insert-pic.-from scaner or cam.-choose scangear- custom insert.
November 7, 2002
Product : IR 2200 / 2800 / 3300
Title : E007 code for the IR 2200 / 2800 / 3300
Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution : In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000).
Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS
