Question about RTO W/ Overflow Chrome 1 5/8" Vessel Sink Pop-up Drain
Vessel sink's drain is leaking
Does not appear to be any of my connections. Vessel has one of those push down stoppers in it's base. When closed, no leaks! when open water leaks out from underneath. I have the rubber gasket between the big nut (underneath) and the granite underside, but water pours out.
Help
Had the same problem and consulted a plumber. Put the entire drain on the sink first. Make the hole big enough to drop the drain down. The base of the vessel sink with overflow should be broader than a sink without overflow allowing you to make a hole big enough. Drop the sink and drain down the larger hole and into the drain system. In this case you tighten the drain to the sink and not to the counter. Silicone under the sink will adhere it to the vanity counter.
Posted on Aug 20, 2010
A waste with a over flow does not work well with a vessel sink because the sink is to thin
Posted on Jun 16, 2009
2 Suggested Answers
  • 2976 Answers
SOURCE: Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Posted on Feb 21, 2009
Pop Up Drain in vessel sink
Have a look on u tube see if there is a video on it .
Oct 08, 2017 | Plumbing
I installed the sink drain with overflow and water is leaking from behind the sink and under the countertop. What did I do wrong.
a vessel I dont beleive has a overflow. you need a differant waste for that unless theres something your not telling me
Sep 03, 2011 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Just installed a vessel sink and it leaks between the vessel and under sink.
Use silicone to seal the flange and teflon tape on the threads that the drain flange screws onto. make sure that the sink isn't cracked. make sure that you have a washer under the rubber gasket that seals the bottom of the sink and tighten the nut against the washer snuggly.
Mar 23, 2011 | Vessel Home
Very slow drain age ,cleaned several times. could cause be vent problems???
Well, it could be a venting issue, but presumably your sink is vented, to pass code. Try removing the stopper and test again. Most stoppers or screen covers slow flow too much, in my opinion.
Oct 02, 2010 | Vessel Island Glass Sink
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
Vessel sink drain causes poolin of water.
YOU ALSO HAVE A VENT ISSUE, THE VESSEL SINK DOESN'T HAVE THE LITTLE HOLE IN IT LIKE A VANITY SINK, THERE FOR THE WATER IS GOING DOWN THE DRAIN BUT THE AIR CAN NOT COME OUT, YOU NEED TO INSTALL A STUDOR VENT OR AN INLINE VENT INTO THE DRAIN BETWEEN THE WALL AND THE TRAP CUT IN A TEE AND BRING A PIPE UP TO THE BOTTOM OF THE COUNTER TOP AND INSTALL THE VENT, USALLY HAVE TO PUT A FEMALE ADPT ON THE TOP OF THE PIPE THE VENT COMES WITH THREADS DO NOT GLUE IT IN PLACE, THEY HAVE A RUBBER FLAPPER THAT OPENS WHEN THE WATER IS GOING THRU THE DRAIN AND ALLOWS IT TO PULL IN AIR THEN THE FLAP CLOSES WHEN NO WATER IS RUNNING TO KEEP THE SEWER SMELL OUT
May 28, 2009 | Ultra Max Eden Bath Black Ultra Zen...
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Apr 10, 2009 | Advent KRAUS Amber Rectangular Glass...
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Pop up vessel sink drain
Look underneath the sink and you will find the lever that moves the drain up and down. It is probably stuck.
Jan 28, 2009 | Ultra Max Eden Bath Black Ultra Zen...
RTO W/ Overflow Chrome 1 5/8" Vessel Sink Pop-up Drain Logo
2,158 people viewed this question
Top RTO Plumbing Experts
Paul Carew
Tom Chichester
Are you a RTO Plumbing Expert? Answer questions, earn points and help others
