Question about Philips 32MF231D Television
No picture but I do have hiss from speakers. Unit was intermittent with this problem so suspected connection/solder problem. Cannot find anything visually wrong. Friend (owner) claims that sound always worked even when picture dropped out. I have looked at the 2200uf caps but they look good and are 35v so I suspect this was a later revision (BZxxx628xxxxxx). I measure about 24v going from the PSB to the backlight board. Seems like that must be right. But I'm not seeing a picture even from ambient light so I'm not sure that it's just a backlight issue. 2 green leds light up on main board when it's "on". Another solution here suggests that the main board is hosed. I'd like to be a little more sure before ordering a new one.
  • 2 more comments
  • Chmed Jul 29, 2009
    Ok, so i bought a used lcd drive board which is located under a large piece of sheet metal (under the power supply and main input board. This new piece did not fix the problem so I swapped it back to the board that came in the TV. But at this point I did discover that I could see an image when pointing light into the screen at the right angle. So I bought a used backlight board (to the side of the power supply). This replacement made it light up correctly. But then I noticed that the left half of the screen had a different hue to it than the right. On a blue screen you couldn't tell but on the menu it was obvious. So I swapped the lcd board back to the newer one. And voila, it's working.
    Thanks
    Ok, so i bought a used lcd drive board which is located under a large piece of sheet metal (under the power supply and main input board. This new piece did not fix the problem so I swapped it back to the board that came in the TV. But at this point I did discover that I could see an image when pointing light into the screen at the right angle. So I bought a used backlight board (to the side of the power supply). This replacement made it light up correctly. But then I noticed that the left half of the screen had a different hue to it than the right. On a blue screen you couldn't tell but on the menu it was obvious. So I swapped the lcd board back to the newer one. And voila, it's working. Thanks.
  • Chmed Aug 31, 2009
    The board that actually drives the lcd panel is underneath some sheet metal. I ordered a used LCD driver board (CPT-320WA01) from a seller on ebay thinking the problem had to be whatever was driving the lcd but this did not fix the problem, initially. After I discovered that it didn't fix it I swapped back to the original logic board in order to send the newer one back. But instead of sending it right away I decided to order the voltage inverter board (CPT-320WA01C) from the same seller. This fixed the no image problem but showed another problem, the left side of the screen had a different hue to it compared to the right side. There was a distinct division up the middle of the screen. So, I swapped the newer logic board back in and low and behold, it works.
  • Chmed Sep 01, 2009
SOURCE: horizontal and vertical lines
I am having the same problem with my TV. I believe that the Y-Buffer Driver IC's are bad. There are two small boards on the left hand side(looking at the TV from the back) with 6 small heat sinks on each of them. If you look closely at the boards, it ill say Y-BUFFER on them. There are ribbon cables that run from them to the Plasma screen.
In my TV, several sections of the screen do not have lines in them. These driver IC's are not hot, however the sections of the screen that have lines in, the drivers are hot to the touch. In order to verify that the chips are indeed bad, I am going to swap one that I think is bad with a good section and see if the problem moves. If this is the case, the boards can be swapped out, or chips replaced depending on what kind of parts I am able to find. The chip that they use is SN755867. I haven't been able to locate a source for the chips yet.
Posted on Jun 29, 2008
  • 138 Answers
SOURCE: philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Posted on Aug 19, 2008
  • 138 Answers
SOURCE: 42PF5321D/37
Measure the connector from the logic board to the power supply the second pin from the left it will say Vs_ On if the set has 3.1 volts the problem is the SSB or the logic board. On the logic board there should be a solid led and a flashing led that shown that data id flowing and the problem is the SSB. The SSB is easy to replace just remember what you tokk loose and from where. You probely will save money that way. If the set is in warranty or just out of warranty contact Philips 1-888-744-5477 and see what they can do first.
Posted on Aug 20, 2008
  • 11 Answers
SOURCE: I have a Philips 30PF9946D/37 no picture
what you have is a bad inverter transformer on the inverter board. I nashed my teeth on this problem for a long time because no diagram is avail. Here's the fix for you:
Remove the invertor board. Take an Ohm meter and measure the outer 4 legs of each transformer. Between pins 1 and 4 (side with the white dot near leg 1) you should read .3 ohms. This side is usually good. Between pins 5 and 8 you should read approx 1.8 to 1.9Kohms. ANYTHING above that is a defective transformer. I'm sorry I do not have the part number for this, I've just been using an old board from a set with a cracked panel. If I can find a part number I will try to post. You can try Encompass parts on the web, they may be able to supply part number and transformer with location number.
Rick
W2ICA
Posted on Mar 19, 2009
SOURCE: magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Posted on Mar 27, 2009
Reoccurring audio problems
All TVs today are actually computers which also receive TV frequencies. The audio has to be decoded from the digital signal then goes to an analog audio amplifier. When you hear no sound with the picture do you hear anything coming out of the speaker? A hissing sound when the volume is way up?
If you hear a hiss then the amplifier is working but not getting anything to amplify. This could be due to a bad solder connection or a problem with the CPU and/or a switching circuit. Without a schematic I'm guessing here.
The bottom line is, there's probably nothing you can do to fix it unless you're used to dealing with SM (surface mount) technology and can touch up all solder connections from the CPU to the audio amp.
Whoever is fixing the TV should be able to tell you where you're losing the signal from the RF decoder to the amplifier as long as the problem is not before the decoder (which is probably all in software that the CPU runs.)
Oct 05, 2017 | Mitsubishi LT-40153 LCD TV
Is it dead?
Check its video output card for any loose solder terminals. This card can be located at the base of the picture tube, directly plugged on to it. Check all solder terminals here. It is a best practice to resolder all the suspected solder terminals, by applying a little more fresh solder. resolder all the CRT base socket solder terminals too. If the solder terminals that connect the filament of the picture tube got loose soldered, this kind of fault can occur intermittently.
Jun 22, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a sharp tv with the volume at its highest but i can't hear anything
Hello
Check its speaker first. If voice coil of the speaker or tis cone paper has damaged, speaker will produce a dull low sound output. If the speaker is found OK, check the audio output section of the unit. This section circuits can be located inside the TV circuit board. look for any loose or bad soldering terminals at the audio output IC. It is best to resolder all the suspected solder points by applying a little more solder, withut making any solder bridge short in between adjecent solder terminals. If this also does not help you, replace the audio output IC. It is damaged. OK.
Dec 26, 2011 | Sharp 13VT-R100 13 in. TV/VCR Combo
I have a TN55x81. the picture will just stop working (goes black). I will shut it off for about 5 minutes and then it will work fine. Some times for 2-3 days and other times just 10-15 minutes. Any ideas??
Intermittent problems on this type of TV are often because of cracked solder joints on the circuit board. They can be hard to see. When the TV gets warm, parts on the board expand and move by tiny amounts, sometimes with the right amount of expansion or vibration from the speakers, the broken solder joint looses connection and the unit shuts down. When things cool-off, the contact can be made again all by itself and everything fine until it happens again. Given the random nature of your problem, this is a suspected problem. Often it is the solder around the lead of a large component which is mounted to a heatsink.
Jan 22, 2011 | Toshiba TN55X81 55" Rear Projection...
My Hannspree TV volume goes out intermittently. Any way to fix this?
there's no faulty parts on your unit but sure that you have a dry joints on the sound amplifier section.
Look for a qualified technician to re-solder for a dry joint on the said section and it will fix the problem.
If you have knowledge in soldering then open the back panel of your tv.
Then observe first because you have to pull-out some connector from the main board.
Remember that anything you pull-out will be back to their position as you finished resoldering.
Try to trace the connectors of your speaker to the main board.
It is connected to ic which have a heat sink.That's the sound amplifier ic.
Find the cold solder around there then resolder it.
You can try the tv, if you hit the cold solder then intermittent sound will be cured.
Remember that before you try turning on the unit be sure that you returned the connectors to its original position. gud luck buddy...
Thanks for using fixya...
Jan 09, 2011 | Hannspree (K206-10U1-005) Television
One of my speakers has a constant hum and an intermittent crackle/hiss while music playing. Please help!
Swap speakers from the output of the receiver or amplifier. If you hear it from the same speaker, then the speaker is bad.
Nov 10, 2010 | M-Audio BX5a Speaker
My mission Mv-as subwoofer has an intermittant problem - it works for a short time and then the unit fails to function. there is not a problem with the power and the speaker unit is not damaged. is this...
Yes , the possible fault can be a suspected fault in the sub woofer power amplifier. You will need to remove to check the circuit.
It can be a faulty or dry soldering in the main board., re solder IC.
Also if the IC is faulty it can be erratic, a signal test must prove it right applied to the input.
Oct 27, 2010 | Audio Players & Recorders
Panasonic CT-32G6E Intermittent single horizontal line
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
Aug 07, 2008 | Panasonic CT-32G6 32" TV
Yamaha nx sw300
Ditto, i've got all 5 speakers without the Subwoofer. The subwoofer hasn't worked from day one, but I delayed replacing the unit for too long and don't have the warranty, I looked at all soldered connections and none of them have come un-soldered and all connectors are properly connected, can't think of anything but broken component that would cause it from here, nor can I think of a quick fix
Nov 17, 2007 | Yamaha YST-SW160 Subwoofer
LG42PC1D failure to switch on
Usually this problem is caused by poor solder connections on the main power supply board. The unit being a plasma tv has many supply voltages and sometimes has multiple power supply boards. By removing these boards and resoldering any suspect connections, the problem is usually resolved. Many companies will do anything to avoid repairing a unit that is working, even intermittantly. Call the responsible parties and demand that they service your unit properly, not brush you off. Scrivitron
Jun 11, 2007 | LG 42PC1DA 42 in. Plasma HDTV
Televison & Video Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
