Question about Sony Cyber-shot DSC-W50 Digital Camera
When I turn the camera on, the lens keeps going in and out...
When I turn my camera on the lens keeps moving in and out and the screen says "access" and than says turn off... I dropped it once and it hasnt worked since....Wondering if there was any solutions to try before I go out and buy a new camera
    Novelist:
  • 107 Answers
When you drop your camera two things may happen.
1- Some mechanical part of the lense mechanism may have been damaged or broken. You would have to open the lense and check for broken parts, damage parts disconected cable. It is not advisable for most people to open the lense and put it back together. You would most likely make it worse.
It usually cost more to fix it than, if you invest in new camera.
2- If some dirt somehow got on the side of the lense, they may cause your lense not to open 100% when you turn it on or retract 100% when you turn it off. I had the same problem with my sony cyber-shot DSC-w7 which is very much similiar to yours. Here is what I did and my camera is working fine ever since.
I cleaned around the lense.
While I turned the camera off, I pressed the lense in (up and down and turning motions) Not too hard for a few times untill the lense retracted over 90% of the normal.
I then push the lense a little harder so that the lense was 100% retracted.
After I turn it on and off a few times, the lense opened and closed as it does normally.
If you try this, it should get fixed if it is fixible.
If it was not fixed and you decided to buy a new one and you intend to trash it. Give it to someone like me who loves to open up and mess it up or sometime fix it.
Good LUCK !!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 16, 2009
  • 3 Answers
(((SLAM IT))) I read on HERE (but can't find the exact link anymore) several others suggest slam the camera on it's side and VOILA, mine is WORKING AGAIN!!! YAY!!! I banged it on my coffee table.... falconree@aol.com
Posted on Jul 08, 2009
I had the exact problem.
The Sony website or manual does not show how to troubleshoot this. I called them and they weren't able to help me. However, I gave it a jolt against the wall and a towel so that it wouldn't scratch and it started working again. Not too hard but hard enough. It was either that or pay $91 to ship it. Well, it worked and from what I hear, it also worked for other people as well.
Posted on Jul 07, 2009
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
The screen will not show the image. it looks as if the screen is cracked, but there is no crack on the screen. also the zoom will not go in or out. the camera turns on, you can hear it and the lights on...
firts resolve the lens issue
1.- Clean the lens surface with a soft cloth (clean the cilinder body of lens)
2.- Turn OFF the camera.
3.- Gently Push the lens
4.- Gently PULL the lens while you turn ON the camera
Check if the lens go in and out. If the lens don`t move try again step 2 to 4
If the lens move, and the Screen continue NOT image (screen is white) you need replace the lens sensor
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Kodak EasyShare Z650 Digital Camera
My digicam lens keeps on moving... coming in and coming out and the screen says "ACCES"
The ACCESS error message displays when there is an internal malfunction or a malfunction with the Lens. This may also appear when accessing the Memory Stick for reading or writing the data. If the Lens is moving in and out then follow the steps mentioned below. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa
Jan 19, 2011 | Sony CyberShot DSCS750 Digital Camera
My digital camera FinePix A900, keeps turning off when I turn it on. Unable to pull any menus. Batteries are good. any suggestions, is it fixable or do I have to buy a new one?
Try pressing the playback button to turn the camera on. This should turn the camera on just so that you can view any pictures stored on the card or internal memory. You can also access the menu functions this way. Also try pressing the picture/shutter button and see if the lens extends. If the camera shuts off when you press the picture button and the lens does not move or only moves a fraction then the problem is probably to do with the lens
Dec 18, 2009 | Fuji FinePix A900 Digital Camera
Olympus FE 270 Digital camera lens, screen, etc not working
Hi!
Hi!
The focus is stuck. Could be sand, dirt or something in the focus gears - well known problem for these lens. Contact your local Olympus service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
Tom
Jul 03, 2009 | Cameras
Access problem
Get it serviced. U've prob. dropped it and the lens is no longer in allignment (retacting issues)
Jul 07, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lens coming out and going back in when turned on
Lightly hit your camera in you palm a few times. I has the same problem with my DSC-W55 and it works now!
Oct 12, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Getting access
Was your unit dropped, or maybe left with the lens protruding? Seems you have a problem with the lens assy(stucked), during start-up, it will initialize to check if all systems go, if not then it will display turn off and on again. thanks
Sep 06, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Camera will not go past this mode.
Firmware problem. Check your Manuel for fault types contact Sony Tech support Team
Jul 11, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
270 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
