Question about Goldstar MV-1501 Microwave Oven
My Goldstar MV1501 1000 watt microwave has no power. No lights, no nothing. there is power to the outlet. I can't find the fuse that I'm supposed to replace.
    Sergeant:
  • 249 Answers
Should be pretty close to where the power comes into the oven,there is a fuse! keep looking
Posted on Jun 16, 2009
What is watts for goldstar MA 1280M Microwave and if it is over 1100 watts cani i adjust it down
You can set it to different levels. It is doubtfull the magnetron will deliver more than 750 Watts as that is about all they can produce singley. Commercial ovens use at least two magnetrons.
Most specs on microwave ovens quote the power drawn not power produced.
I hope that helps.
Jan 01, 2011 | Goldstar MA-1280M Microwave Oven
On a goldstar microwave oven model mv-1500mg, after pressing the light button, there was a bang and then no power to anything. I have checked the electrical outlet and there is no problem. Thanks for your...
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Dec 19, 2010 | Goldstar MV-1526 Microwave Oven
No power but outlet is functioning properly
There is a ceramic fuse inside the oven. Remove the case and follow the cord from the back of the oven to the fuse. Replace with on of the same amp size.
Jun 19, 2010 | Goldstar MV-1501 Microwave Oven
The mircowave has no power, outlet works, just mirco strop workin
HI, the popping sound that you herd was the result of a failed HV capacitor. This failure will render the unit inoperable, as you has witnessed at this time. Replacing this failed HV capacitor, will correct this issue. I would also advise to check the cut-off fuse and in-line AC fuse as well. There may be some issues concerning the integrity of these fuses as well.
Sep 11, 2009 | Goldstar MV-1501 Microwave Oven
Completely stopped working
sounds like you blew the fuse inside
Jun 19, 2009 | Goldstar MV-1526 Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar microwave mv-1526 1000 watts
the bullet fuse to the klystron circuit may have blown
it is a thermal bullet fuse ,
google that to see what it looks like.
if you have a ohm meter it will give low ,closed resistance.
Apr 25, 2008 | Goldstar MV-1526 Microwave Oven
Microwave has no power
Is the outlet ok? Can you plug somethng else into the outlet to see if the fuse or breaker controlling the outlet is ok? If there is power at the outlet, unplug the unit and remove the outside cover.
Look for a blown fuse on the motherboard. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged. Was this a power outage or surge? Was anything else in your home affected?
- Jim
Jan 29, 2008 | Goldstar MV-1526 Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
206 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Mike
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
