Question about Dryers
My GE DBL333EB1WW squeaks and I have no idea why. I hear it could be the bearings wearing out or maybe the belt. I dont want to pay someone and would like to troubleshoot and fix it myself. Any pointers on where to start?
    Sergeant:
  • 249 Answers
Could be the drum seal dried out causing the squeel
Posted on Jun 16, 2009
How do I stop my GE dryer from squeaking
Check belt look for location of noise and look for items in that area you should locate with process of elimination .
Mar 03, 2016 | GE Dryers
Tip
Gas & Electric clothes Dryer sqeaks, rumbling, & noises
If your clothes dryer has any sort of uncommon noises coming from it they are fairly easy to repair. The drum turns with the help of a belt with a belt tensioner. The tensioner keeps the belt tight. The tensioner also has a roller with a bearing. If the bearing goes dry it will squeak. If the bearing locks up the belt will burn and you will smell burning rubber. Eventually the belt will break off. The roller can be ordered from most companies with the belt. It is advisable to replace the drums front seal that rides along the front panel. These will wear and squeak too in time. To service these parts the front panel must be removed to gain access. All parts are fairly easy to repplace with someone helping you to hold the drum up when re assembly come up. You can also ask me more questions if needed.
Thanks for stopping by reading my tips!
frank
on Feb 06, 2010 | Washing Machines
Constant loud squeaking
Squeaking is normally caused by a bad bearing or a slipping drum belt.
Feb 28, 2015 | Dryers
Our clothes dryer squeaks when it is drying clothes. How can it be fixed or what is the problem?
Most time them squeak is like bad brake pads on a car. The plastic bearing is gone and now the drum is riding on the metal bracket. The front of the drum rides on slides and when they wear out you get a scrubbing sound and not so much a squeak. So i would say you have a GE/Hotpoint type dryer with a rear bearing that looks like this:
WE3X75
My Dryer problems and solutions blog page
How it works: GE clothes dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 31, 2011 | Dryers
My ge profile dpsf495ew dryer is make a squeaking noise
It's the drum bearing . It's in the back of the drum but it can only be accessed from the front. It's regular wear and tear that causes this usually. It's a pretty tough job for someone that has not done it before.
Jul 01, 2010 | GE Profile DPSF495EW Dryer
I hear a squeak, and was going to go and look at the belt, but how do I get the covers off to look at them?
Ths squeak comes from a thinly worn out bearing part number we3x7570779c7.jpeg
Then get the front off
9c55f3f.jpgthen get the drum out
The beagoes into the center hole in back
Mar 10, 2010 | GE DVLR223 Dryers
Engine Squeak on 1986 Grand Marquis
Yes. Squeal is from a/c compressor. Belt too loose.
Dec 07, 2009 | 1986 Mercury Grand Marquis
Dryer squeaks when drying clothes
try letting the mouse out??? its likley to be the drive belt or rear bearing dry,,, could be the motor bearings dry,,
back bearing and motor bearings could be lubed with WD40 but dont put it any were near the drive belts as they will then slip like mad,
spray on the driv belt a bit of "stop squeak" its for car fan belts realy but it works on any rubber belt
Oct 24, 2009 | GE DRSR483ED Electric Dryer
DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Apr 07, 2008 | GE DCSR483EA Electric Dryer
GE Spacemaker washer/dryer
If you can get it apart, you should be able to fix it yourself. This is a tricky task though (I've seen customers spend hours just trying to change a belt, which you'll have to remove), so you may want to pay the money and have someone come out.
It is hard to say without hearing the noise for myself, but my best educated guess would be that the dryer drum bearing needs to be lubricated. You should lubricate it with white lithium grease, about 1.5 ounces of it.
In order to do this, you will have to take the dryer front off, remove the belt from underneath the drum and then remove the drum. You will see a bearing on the backside of the drum (looks like a post with a ball on it). You will see where that inserts on the back wall of the dryer. You should put the grease in the insertion point, then put the dryer back together again.
Mar 29, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryers Logo
189 people viewed this question
Top Dryers Experts
Marvin
Marvin
