Question about Hunter Fan Company 5/1/1 Programmable Thermostat
I am trying to hook up a Hunter 44260 t-stat. The old one(not sure of model) has the following hookup. White-O Terminal Green-G Terminal Red-RC Terminal Yellow-Y Terminal then jumped to W Terminal Blue-Spare My problem is that the Y/O and W/B terminal on the Hunter is on different blocks. Should I wire the yellow to W, white to O, and jump them together, or what. And should I leave the blue wire off, or put it somewhere?
  • 308 Answers
Here is some basic info to help you. On the thermostat the letters mean... G is for your blower fan, and is usually green, Rc and Rh are power for the heating and cooling circuit (24v) and are usually red; Y (or in this case Y/O) is power to the cooling contactor (outside the house) and is usually yellow, and W (or in this case W/B) is the common wire, and is usually white. It kind of sounds like the people who installed the old thermostat followed these guidelines, so your best chance is to go to the heating unit and seeing where the wires connect to. Hope this helps
Posted on Jun 17, 2009
Trying to replace my old t-stat to a Hunter 44260 t-stat, the old wirings are :Rc-Rh(jumpered), G,Y,W, O & B and the new t-stat has G,Rc,Rh,Y/O,W/B & Y1, i dont know where to connect the old wiring...
It sounds like a standard gas fired heating system and electric cooling. Leave the jumper between the RC and RH and attach the red wire.to one of them it does not matter since they are jumped. Attach green to G attach the white to W attach the yellow to Y if there is no C screw on the new thermostat leave the blue wire disconnected and not touching anything. It is the common and many systems use feedback to provide the common power. The O & B terminals are used for heat-pump systems only. Their purpose is for the reversing valve. Depending on the make or model either the O or B is used not both but remember the O & B are for heat-pumps only not gas fired furnaces. NOTE the best wiring practice is strip the wire with your thumb nail not wire strippers they tend to leave nicks in the wire and will break in the future also wrap the wire around the screw in a clockwise direction it will pull the wire into the connection tightly if you wrap the wire counterclockwise it will push the wire away from the connection. Good luck. I assume the new thermostat is digital. If it is not digital the heat anticipator must be set. If that is the case let me know and I'll give you instructions on how to set it.
Oct 21, 2012 | Hunter 44260 Set and Save 5/1/1...
Changed honeywell T8400C 1024 to Hunter 44760, I have five wires white, red, yelliow, green, blue. Hunter Thermostat reads "NO A/C Power.
On the t-stat and the furnace make sure the wires are hooked like this...
Red to R
White to W
Green to G
Yellow to Y
Blue to C
then it should work..
Thermostat Wiring and Terminal Designations
heatman101
Jun 12, 2011 | Heating & Cooling
I do not know where the wires color coded connect
if there is a jumper across Rh and Rc then leave it, if not add a jumper and hook the red wire to one of them. Hook the white wire to the W/B terminal, the yellow wire to the Y/O terminal, and the green wire to the G terminal. If the A/C does not come on with ti this way then hook the yellow to the Y1 terminal instead of the Y/O, I'm not exactly sure which one it will be but it will be one of those. The blue wire you should not need to hookup if there is no C terminal on your t-stat. Just wire nut it off and let it there. This should get you up and going!!
Nov 14, 2009 | Heating & Cooling
Three wire system, going to a five terminal thermostat? Wires from wall are red, white and blue. Terminal on new thermo is yellow ,green and then on the next row is,Rh, Rc, and w How does that work out? My...
The Rc and Rh should have a jumper wire between them let it in. and hook the red wire to one of them it does not matter which one as they are jumpered. The white wire goes on the "w" terminal and the Blue wire will go on the "G" green terminal to run your fan.
This should get you up and running again!
Nov 13, 2009 | Honeywell Programmable Thermostat Heater
I have a Red, White, Blue and Green wire , need to wire a Hunter B01 MOdel or 44110 Thermostat has the following ports available G, RC, RH (RC & RH Have a jumper between them), Y/O, W/B, Y/1
From what you describe you have a heat only system with no AC. If that is so, then you would wire it as follows.
Red wire = RC (leave the jumper in place)
Green wire = G
White wire = W/B
Blue wire = is unused because the thermostat is battery powered and does not require a common wire.
I reccomend you consider not using the Hunter T-stat. They are so extremely problem prone and unreliable. You will be much better off with a Honeywell or White Rodgers T-stat.
You will also need to program the Hunter T-stat for your system per the instructions.
Oct 04, 2009 | Heating & Cooling
I have a travel trailer with a roof top a/c colman mach111 and I hooked up a thermostate digital. The heat works but cant get a/c to come on. the termanials on hunter thermostate are G W Y RC RH
OK, the wiring that you should have in your RV is as follows: Red White Blue Yellow Green Gray.
This Thermostat will not work on this Air conditioner because the tstat you are installing is a 24V thermostat. The connections are as follows G = Fan, W = White, Y = Cooling, RC = 24V Cool, RH = 24V. The only thing that I can think to do is hook it up like so.
On the G Terminal, Hook up the Green wire from the wall. On W, hook up the White wire, Y, hook up the yellow wire. RC = run a jumper from the RH terminal, RH = hook up the red wire. If this doesn't work then you will have to go back with the coleman thermostat.
Jul 03, 2009 | Heating & Cooling
I am trying to wire a hunter 44550 to furnace. Old programable not much help. Hi have 5 wires comming from wall. Black, red, yellow, white, blue, Furnace has W, RH, RC, G, Y/Y1, and O/B terminal Any idea...
Depending on where the wires were connected on the old thermostat, would be the best place to start, but if that is not an option you could try to trace the wires back to your furnace and see where they connect to. It appears you have either an oil fired furnace, or a single stage heat pump. If you need more assistance please just provide type of heat used. Hope this helps
Mar 07, 2009 | Hunter Fan Company 7-day programmable...
Wireing code from goodman heat and air to a Hunter 44360 programa
To get your heat going take the red wire hook it up to R on t-stat. Take white wire and hook it to W on t-stat. Take the green wire and hook it to G on t-stat. that will get you heat. Now I need for you to go to the unit where the wires hook to the furnace circuit board. I need to know what color wires go to what on the board. Might have to take off bottom panel. should only be using 4 or 5 wires. Get back with me and will complete the wiring. Be sure no wires at the t-stat are touching each other as this will short out transformer. So tape them off or cut flush so wire and insulation are flush. ken
Dec 11, 2008 | Goodman CLQ36AR49 Air Conditioner
I have an older Carrier Heat Pump which I am trying to update the thermostat control with a Hunter model 44550. The problem is that the wiring to the current thermostat is as follows, G= green wire, R=...
JUMPER STAYS BETWEEN RC AND RH SO YOU HAVE INCOMING POWER FOR BOTH COOLING AND HEATING. THE WHITE WIRE YOU SAID C IS COMMON AND SHOULD BE USED IF POSSIBLE TO COMMON TERMINAL ON NEW STAT . IF THERE IS NO COMMON, THEN CAP IT BUT YOU'LL BE CHANGING BATTERIES EVERY FEW YEARS. I LIKE THE STATS WITH A COMMON POWERED OFF THE TRANSFORMER BUT YOURS MAY NOT HAVE A COMMON. THE GREY WIRE CONNECTED TO THE E TERMINAL IS FOR EMERGENCY HEAT. IT KILLS POWER TO THE HEAT PUMP, HEATS THE HOUSE ON IMMEDIATE CALL FOR HEAT WITH JUST THE INDOOR BLOWER AND THE INDOOR HEAT STRIPS. THIS PREVENTS ANY DAMAGE OR INCREASED DAMAGE TO THE COMPRESSOR IF YOU SUSPECT A PROBLEM.YOU SHOULD HAVE A TERMINAL ON THE NEW STAT THAT IS MARKED E OR PERHAPS X2 OR W3. THAT IS WHERE THE GEY WIRE GOES. IT IS POSSIBLE THE WIRE CONNECTED TO W DOES THE SAME THING AND YOU CAN GET BY WITHOUT THE GREY WIRE CONNECTED.ALSO SELECT SINGLE STAGE HEAT PUMP. SINGLE STAGE COOLING AND TWO STAGE HEAT . FIRST STAGE HEAT IS YOUR HEAT PUMP AND SECOND STAGE IS YOU STRIPS.
Oct 26, 2008 | Carrier Heating & Cooling
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
333 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
