Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Mac not allwoing write permission to an external hard drive
Whenusing a maxtor 1tb external hard drive that was formatted and "filled" using a windows based machine i now have a mac and whilst the mac reads all the file types fine it hasn't let me have write permission on the folder. also when using the disk utility the repair/verify disk permission links are grey??
any help much appreciated!!
  • 31 Answers
As long as the Esternal is formatted correctly it should work fine, it might be that you computer wont read the hard-drive, not the files.
Posted on Jun 16, 2009
  • popemohamed
    popemohamed Jun 16, 2009
    sorry I meant esternal
  • popemohamed
    Sorry I cant believe I did it again I meant External
How do i reformat my external hd
if your using windows just right click on the drive and select format. in mac go to disk utility and select drive. choose erase and erase drive using either fat32 if you want read/write support for windows or just format as mac journal
Feb 23, 2012 | Western Digital My Book Essential 1TB...
My Book formatted NTFS attaching to Mac
If you want to exchange data files between a PC and a MAC then your My Book 3.0 external hard drive needs to be formatted in FAT32. Use a PC to format the external USB hard drive in FAT32.
If you only want to use the external hard drive on the MAC then use the MAC to format the hard drive in HFS+
Dec 25, 2011 | Western Digital My Book Essential 1TB...
Is this external drive compatable with mac?
It should be but may need to be formatted as GPT on the Mac after which it can only be used with Windows Vista, Windows 7 or later as XP and earlier versions of Windows cannot read GPT drives.
Nov 09, 2011 | Western Digital My Book Essential 1TB...
I have a wd elements 1tb external hard drive, I feel as if it is not compatable to my Mac when I connect it I can view the folder but I can neither add files nor delete them from the external hard drive. I...
MAC computers use a different filesystem to arange data on your hard drive, if you are switching back and forth between Windows and MAC platforms, you will need to reformat the drive to the FAT32 filesystem.
To do this, from your Windows system, connect your drive, right click on the drive and select Format, select FAT32 from the Filesystem drop down menu. Once the format is complete you should be able to use the drive on either system.
Aug 25, 2011 | Western Digital 1TB WD ELEMENTS USB...
Use my drive on Mac..
Both OSs have different Security Architectures. NTFS for Windows and HFS+ for MAC. So if you modify these permissions (you could) your MAC OS might not be able to access it properly. But MAC will read NTFS permission (But not write onto the disk).
Jul 11, 2010 | Fantom Drives 300 GB Hard Drive
So, my external hard drive was once used on a computer using Windows. Everything that has been installed onto this is locked. My computer is a Macintosh. I cannot add new files or delete the old ones from...
If your external HDD was used on a windows machine, it was probably formatted in the NTFS file format. Mac uses Fat32. The entire HDD has to be formatted to Fat32 for the Mac system to use.
Jan 28, 2010 | Maxtor OneTouch II Hard Drive
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Drive Wont format
First, because they came from the Lacie external drive, they were raided to look like a single drive. To format them inside your computer. You have to go into computer management to initialize each drive at a time and format them by right clicking on the drive and format
May 06, 2009 | Maxtor Hard Drive
Formatting my Freeagent 1tb external hard drive for my Mac?
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Mar 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor 300GB--can't delete or write
You didn't specify if the original PC was Windows or MAC.
Is this USB external used on a PC with Windows? If so is it formatted NTFS? If so, Mac OSX and pretty much everything else but windows NT, 2k and XP can not write to NTFS. OSX and Linux will read an NTFS partition but at this time not write to it. If your drive is formatted NTFS, I would say, go to a windows machine and convert it to a FAT 32 Partition. Most everything will both read and write to FAT32.
Jan 10, 2008 | Maxtor OneTouch II external hard drive...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
264 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
