Question about Whirlpool GS5SHAXN Side by Side Refrigerator
Water leaks out on floor on freezer side and ices up on the freezer bottom below drawer.
  • reelrodcover Jun 17, 2009
    So you say that the defrost water is leaking onto the freezer floor. Is there a pan to catch the water and is that the problem?
  • Whirlpool Master
  • 4,655 Answers
You possibly have a defrost drain problem or your ice maker is leaking. I will help you through this if you like. Let me know, Thanks, Sea Breeze
Posted on Jun 16, 2009
  • John Tripp
    John Tripp Jun 17, 2009
    Thank you for your vote......Sea Breeze
  • John Tripp
    Yes there is a condensate drain behind the back panel inside the freezer compartment. It collects the defrost condensate and sends it through the wall of refrigerator and down the back into a pan beneath your refrigerator and beside or on compressor. Then as the condenser fan below runs the condensate is then returned to the air inside your home. Sometimes there is ice frozen in the drain entrance or a blockage near near the freezer area causes the water to overflow the collection tray and the overflow ends up on the freezer floor or the fresh food section floor. If you still have problems I will be here to assist you, Thanks Sea Breeze
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
Leaking water on floor.
This is typically caused by the defrost drain. I have put together some instructions on how to resolve this, follow the link below and let me know if it helps.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
May 10, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
Leaking by freezer door in bottom
your drain line is clogged remove back wall and trow hot water in hole please unplug unit
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Water drains internally at back of freezer drawer
Check the drain.
Take the bottom drawer out of the freezer and look in the very back for a drain hole. It may be covered with ice. A hair dryer will melt the ice so you can unclog the drain.
Dec 30, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
220 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
