Question about Acer Aspire One AOA150-1784 Netbook
The Y key was sticking on so I popped it off (worked) and now how do I put it back on?
  • 378 Answers
Just push it back.
Posted on Jun 16, 2009
White macbook 10.5.8 pop spilled on keyboard
Ooouch ! After you've dabbed up (the spill) as much as you can, you may find some keys sticking ... i.e. when you touch (push) it (down), it doesn't pop up immediately. These are the keys you'll want to clean individually.
You can pop off the key top off (with your fingernails) from the top corner of the key. Once the key-cap top (cover) is pried open, lift the key-cap upwards and detach it from the bottom edge. You'll hear pop's when you do this. Once the key-cap is off, you'll see the mechanism under it. You'll want to clean things as best as you can ... very carefully. If the underside of the key top (cap) is sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it). Often the "stickiness" is caused by the (white translucent) plastic pieces (at the very top) not dropping flat down (immediately) after you lift it. (You wouldn't want to disassemble the parts below the (white translucent) square plastic pieces. Just clean/wipe it carefully using a cotton swab/toothpick).
You can remove the top (square plastic) pieces by pushing the tabs at the bottom corners ... downwards ... using a toothpick. This "top" square piece is actually two (square) pieces (snapped together), one inside the other. The inside piece is supposed to spin easily/quickly .... if not. it's probably sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it).
The trick is to make sure you know/remember how to reassemble the 2 pieces (after taking it apart and washing/rinsing/drying it) applying the right connection points to fit ... before you put the key-cap back on . The key-cap is put in place by just putting it in place and pressing down to snap it back on.
The larger keys (Shift, Space, etc.) has metal bars holding down the cap, etc., so it may take more effort to pop the key top (cap) off.
If you have quite a few to do, and you don't want to risk breaking anything, the Apple store is probably your next stop.
Oct 26, 2013 | Computers & Internet
I got a honda integra 97, there was this slot by the gearbox with a picture of a car key on the side, ive put my key in it then my car wont suddenly work, what the hell did i just do and how can i get it...
You popped the ingition fuse and relay. That is a safety for if your car all of a sudden dies on you, you can stick the key in there and put it into gear to roll it out of the middle of the road or whereever you may need to to be safe
May 27, 2011 | Honda Fit Cars & Trucks
Keyboard sticking
Clean the keyboard. Most of the keys can be safely "popped" out using a nail file or other thin lever. Don't pop out the larger keys, like the space bar, because they have a small wire spring in most models that can make them difficult to reinsert properly. Use canned air, a Swiffer, q-tips, or other methods (nothing wet, but a damp cloth that doesn't drip is OK) to get the obstructions cleaned away and then put your keys back.
Mar 01, 2011 | Logitech Cordless Desktop MX3200...
Delete key of my hp mini laptop is not working. But it automatically pressed asking to delete the file I clicked..
Looks like your delete key is stuck on delete.
Try power off, and restarting.
You might also try to get the keys on and off. You can stick the end of a flat-head screwdriver under the key, twist it to the side slowly and carefully, and the keys will pop right off.
To put them back on, place them where you want them and then push them gently until they click. Just make sure that the key is dead center and push down. If it doesn't sit right, pop it and start again.
God Bless You!
Feb 05, 2011 | HP Mini 1000 Netbook
Keys Sticking
no! you don't want to do that if you unscrew the back plate all the plastic suction cups with fall off and you will never be able to type on it, until you place the suction cups back what you want to do is get some WD-40 (the tool for fixing almost everything) or a can of pressurized air with a areosole top and aim it at the key or under it, press it and it will blow every piece of junk under the keys cleaning it.
Feb 09, 2010 | Logitech Wireless Access Duo Optical...
My zero key was stuck so I took it off and need to put it back on
turn it around in the other direction your zero is upside down..
Jan 11, 2010 | HP Pavilion dv2000 Keyboard
My keys seem to stick a little on my laptop..when i try to type fast it skips letters or the space bar
could be dirt under your keys try cleaning with compressed air or pc cleaning foam and a soft cotton bud, be gentle tho as the keys are very tricky to put back on if they pop off
Nov 24, 2009 | Acer Extensa 4620 Notebook
I have a mac book and two of the keys have popped off. Can they be put back on and How do I do that?
Placing back the keys is not possible manually except that you stick it, and thats the worst thing you would do. if you have an apple service center nearby, get it serviced by them as they need to open the lower case of the macbook to do that.
Btw is it Macbook or Macbook Pro? Because macbook pro has a unibody which can not easily get the keys back into position if they popped off.
Sep 18, 2009 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Card reader not working
Try putting your memory stick on a usb port on the back of the cpu. It may work. Usb ports on the front of the cpu and card reader may not work with all memory sticks
Dec 17, 2008 | E-Machines eMachines Desktop PC
Compaq nx9010 keyboard beeps when it starts up and also this key "l" is stuck it outputs llllllllllllllll even at log on
Ok what you need to do is pop off that key.
Get a small regular head screwdriver or flathead and put it under the key and pop the key up slowly.
See if anything is under it which is making the rubber gromet stick.
If so take some rubbing alcohol and a cotton swab and dip the cotton swap into the alcohol and then clean it with the swab.
Put the key back on.
You will see how it goes when you pop it off the first time.
This should take care of your issue.
If not don't hesitate to request further instructions.
Dec 11, 2008 | HP Compaq Business Notebook NX9010
Acer Aspire One AOA150-1784 Netbook Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
