Question about Toshiba Satellite L25-S119 Notebook
My Toshiba Satellite won't turn on at all
My Toshiba Satellite will not turn on at all, the power light will not light up when put in the charger.
  • 157 Answers
If no lights/nothing happens when you press the power button then you probably have a corroded power socket on your motherboard, the positive terminal will not be connecting properly to the motherboard. The laptop needs to be dismantled and have the socket resoldered properly. This can cost quite a bit at most places. I would check the charger first to make sure it is not the problem.
Posted on Jun 16, 2009
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
My Toshiba Satellite A215 - S7422 won't charge and
a problem with the battery or a charger.
Jul 17, 2012 | Computers & Internet
My Toshiba Satellite L655-s5107 won't turn on.
More than likely the power cord/charger is dead or the battery is. Bring it to a tech store and see if you can test out a new cord/charger and battery......
Jun 29, 2012 | Toshiba Satellite L655-S5107...
Satellite C660-2DL won't turn on
Hi
Try replacing the battery.
Also check whether it charges,could be a faulty charger too.
Feb 22, 2012 | Toshiba Satellite A60 Notebook
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
Hi i have a toshiba a135-s2386 laptop, when i press the power switch the main power light comes on and fan spins but the pc does not post at all
Try doing this: Turn off the computer. Disconnect your charger. Take out the battery. Then without the charger and the battery, press and hold the power button for around 10-15 seconds to drain all the excess power inside it. Reconnect your charger then turn it on. If it turns on, then good. You may put the battery back afterwards. If it did not turn on then it could either be software or hardware failure already.
Dec 14, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite A305D-S6848 HAS NO POWER. NO LIGHTS COME ON AND I PLUGGED THE POWER CORD INTO ANOTHER TOSHIBA AND IT WORKS. NOT A POWER CORD PROBLEM. NO FANS RUN OR ANYTHING WHEN I HIT THE POWER BUTTON....
TRY TO REMOVE THE BATTERY AND JUST PLUG THE CHARGER ON IT AND ON POWER. SWITCH IT ON. IF IT TURNS ON THEN YOU SHOULD KNOW THAT YOU NEED A NEW BATTERY OR IF IT DOES NOT, TAKE IT TO A COMPUTER SPECIALIST TO CHECK ANY HARDWARES THAT ARE NOT FUNCTIONING.
THANK YOU
WONDER
Oct 29, 2009 | Toshiba Satellite A305D-S6848 Notebook
Toshiba satellite p105-s6217 will not power up or charge.
Larry,
  1. Unplug the laptop and remove the battery.
  2. Press the power button down and hold for 10 to 15 seconds.
  3. Press the power button 5 more times quickly.
  4. Plug the power back into the laptop without the battery and press the power button.
If the laptop powers on just put the battery back in.
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite L25-S119 Notebook Logo
1,359 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
