Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Green water Experiencing the same problem. Ph levels really high. Running the filter system 8-9 hours a day, using a pool sweeper. But nothing is cleaning/clearing up the green water. Live in the Pacific Northwest so the weather hasn't been overly hot. For the last week hoovering around the 70 degree mark. Thank You for anything you can do to help us--with out dumping water and starting over again.
    President:
  • Intex Master
  • 1,378 Answers
Chlorine generators raise your pH over time. You will always have to monitor and, on occassion, adjust your pH down using acid. Your water being out of balance likely lead to the green water condition.
Check your alkalinity first and adjust it if needed. Once it is stable, adjust pH using acid, then get your pool shocked to kill off the algae. You made need an algacide too but save that for last and only if required.
Posted on Jun 16, 2009
Ph level and clorine level too high
get in the pool companies to adjust the levels to correct and remove the alge growing in the water
Nov 04, 2017 | Intex Automatic Salt Water System for ...
Problem is test strips indicate high copper ion (pink) and total alkalinity is low (light tan) Free chlorine is ok (between 0.5 and 1) and ph is good. We have this greenish silt like stuff on the bottom...
1st.. Clean the green (algae) stuff out..
2nd. Clean the filter...
3rd.. Repeat step 1 and 2 until most all the algae is removed..
4rd.. Brush you pool with a pool brush to remove the remaning algae...
5th.. Seems like you have the right chlorine level but not running your filter long enough??? After all steps are completed, run you filter at 8 hrs and your chlorinator between 3 to 6 hrs until your pool clears up.. After that, vacuum again and clean your filter... During the summer months, 4hrs is not enough circulation.. Hope this works for you and good luck.. Please take the time to write a comment if this works for you...Thanks..
Aug 07, 2011 | Intex Automatic Salt Water System for ...
Recently installed Intex saltwater system, all of a sudden, have green forming around walls of pool. All levels look okay; except chlorine is a little low and PH is very high...I ran the boost cycle last...
Once you get the "Green" stuff on the walls, you must brush it off.. and one boost cycle will not do.... Make sure you have the correct salt level!!! Keep in mind..big pools can take up to 350 lbs of salt... Now...set you pump at 12 hrs and you chlorinator at 10 hrs between those 12 hrs.. Run this cycle and you should see results within 2 to 3 days... Clean you filter and rinse your electrolytic cell after 3 days because you will have dead algae. After the water turns clear, you can then lower your cycle to 10 pump and 8 chlorinate.. Good luck! hope this helps!
Jul 19, 2011 | Intex Automatic Salt Water System for ...
I run the filter pump then turn on the salt water system for 4 hours and test for the chlorine and it is always very low or no chlorine and the ph is always high
pH will always rise over time when using a salt generator. You'll need to periodically add acid to counteract this affect. As far as low chlorine levels try running the system longer...An average pools circulation system is setup to turn over the pool water once in about 8 hours. Running your system longer should lead to a higher chlorine residual and overall cleaner water.
John
Apr 26, 2011 | Intex Automatic Salt Water System for ...
Water not clear
cloudy water is mainly due to poor pool maintainence.
Your purchase of the salt water system only helped you with not needing to pour chlorine in or float tablets.
You will still need to use chemecals.
I use a good stabilizer to hold the chlorine level longer
I use a non foaming algecide once a week
I also use a water clarifying product once a week
Now on to the clouds :-)
cloudy water is because of not enough sanitizer mixwd with a crappy pump from intex
I do not know the size of your pool so I will just use mine to show you #'s
I have a 7000gl pool with a 2500gl ph pump
A pool needs to be turned over at LEAST 3 times a day so for me it takes at least 8 hours of filtering alone this does not include making chlorine.
Bottom line is you should run your system 24/7 between generating and straight filtering
The only cure for less filtering is to get a sand filter with at least a 1 horse power pump to pump 4000gl and uphaving a sand filter helps trap more small particles than the cartridge filter.
I noticed the difference the first night I had my sand filter. It ran for 6 hours before me turning my pool light on and to my surprise I did not see as many particles passing my light as with the cartridge filter and the second night nothing Crystal clear.
Bottom line is intex pumps and so on are not big enough for the pool it comes with.
The salt system alone with a sand filter is great
Jun 26, 2010 | Intex Automatic Salt Water System for ...
Algae forming in pool
Chlorine generators will slowly raise the pH over time. You will always need to have acid ready to be added once the readings start getting above 7.6. You should try and maintain it down around 7.2 - 7.4 to allow for mistakes.
As for the generator; can you turn up the rate it generates chlorine? I am not as familiar with the intex but other brands have an adjustment knob to vary the rate chlorine is made.
Jul 27, 2009 | Intex Automatic Salt Water System for ...
I have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Jul 12, 2009 | Intex Automatic Salt Water System for ...
High ph, algea, salty taste
You are going to need to buy chemicals anyway (acid for sure and probably algaecide) so find a good pool store tech and have them test your water and recommend the proper doses.
In summary though, you should not taste the salt in the pool and being able to means the salt content is to high. Chlorine generators will not work if the salt is to high and the fix is to drain water and dilute the remaining water until the salt content is no higher than max. No chlorine could explain the algae.
Generators also cause the pH to rise over time so you will need to keep acid on hand to counteract that.
Jul 05, 2009 | Intex Automatic Salt Water System for ...
Salty taste, high ph levels, algea and have shocked pool twice
I'm just now setting up my Saltwater generator...so don't have your problem - yet! Local pool guy tho said with the saltwater systems you need to add dry acid to the pool almost weekly to keep the ph down. Sounds like what you're experiencing. The dry acid was cheap and came in small-ish containers, should last long time.
HTH.
I have an intex chlorinator and an intex 24' x 48" round pool. I added only 250 lbs of salt, but the table said 290 lbs. I never got a "low salt" reading. When the water level got low I added water and...
high chlorine can cause problems too it will give false readings for your ph and alkalinity.
The most important thing to remeber is that there is a sequence to follow.
First buy a test kit for salt about 11 bucks for 10 tests. you need to have the ppm's at 3000
if it is to high drain 20% water re-fill and filter/curculate for 6 hours then test again. once at 3000 then go for your chlorine it should be between 1.0 and 1.5 with a test kit now with those 2 in line go for ph adjustment ph should be as close 2 7.6 as possible. Ph will cause more problems like cloudy water or algea more than anything else.
another thing you need to realize is that the intex salt system sucks. Once you set it for the # of hours to chlorinate you are basically guessing as to what is needed. Yes there is a guidence chart as to hours to run but it is over kill and lets too much chlorine be generated start with 3-4 hours of generating but remember also that at 4 hours generating that is nowhere near enough filtering
you will need to shut power off get it out of sleep mode and continue to filter
on avberage a pool should be turned over 3 times a day my pool 7000gl and the 2000gph all in one intex salt pump needs run at least 10 hours a day alone without the chlorinator
my pool only 18' so with your total gallons it will be longer
one last thing to consider is that when in chlorine generating mode the filter slows down because of all the electronics. You can not hear it happen but if you put your hand in front of the discharge you can tell
Jun 27, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
308 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
