Question about Kenmore Elite 45986 Front Load Washer
My kenmore is rading lf at 17 minutes.
My kenmore is reading LF at 17 minutes.
  • 15,935 Answers
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
My Kenmore top loading series 700 type 580 is given me a LF code can u help
LF is the error code for Long Fill.
Sometimes a bad or plugged water inlet valve YOU MAY need to replace the water valve.
In SOME cases the drain hose wash may be siphoning the water out of the washer as it tried to fill.
pulled the drain hose up out of the stand pipe a little to keep it from siphoning
Read more: http://appliancejunk.com/forums/index.php?topic=10002.0#ixzz3bkyrg7TS http://appliancejunk.com/forums/index.php?topic=10002.0#ixzz3bkyrg7TS
May 18, 2015 | Kenmore Washing Machines
What is the LF code on my kenmore elite oasis
The LF code stands for long fill.. I would suspect a water inlet solenoid valve as the most likely suspect. It may be the hot or the cold valve. If the valve does not completely open the time to fill your machine takes too long. You can't replace just the one valve because the part contains all of the water inlet valves. That of course jacks up the cost but what can you do.
Jun 29, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
What does LF mean - my kemore washer quit working
hello
mean while LF error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
The LF error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the LF error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Kenmore 24032\24036 Top Load Washer
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Keep getting an LF error
Hi There
I have found something for to read and this should help you. Try this and let me know how it goes.
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya. Merry X-Mass and a Happy New Year.
Best Regards Richard
Dec 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
WHAT IS THE PROBLEM WHEN YOU GET THE LF ON THE
LF Long Fill
Oct 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LF code comes on frequently
I had the same problem. I pulled the drain hose out and it made a strange gulping noise, as if it was plugged up. Now it works fine. I think LF stands for low flow. Maybe your drain isn't working right.
Jun 19, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Oasis elite top load washer
LF code LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
You will need to check you fill hoses this is 95% of the problem in the rear of the unit ther are two hoses Hot and Cold feeds shut off the water and Unplug the unit Then remove the hoses from the machine. in the Valve where the hoses go to there are little mesh screens they are most likely clogged take a eyeglass screwdriver or paper clip and hook the screens pull them out carefully and clean them reinstall and connect hose and test
Dec 19, 2007 | Kenmore 24032\24036 Top Load Washer
Lf what does it mean?
Lf means long fill make sure your taps are on. or your filters in the hoses arn,t plugged in other words it is taking longer than 10 minutes to fill
Dec 11, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
66 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
