Question about Sony PlayStation 2 (PS2) Console
I have the same problem
My ps2 no data even with a disc then i put pressure on it it says reading disc but doesnt work plaese help
    Problem Solver:
  • 13 Answers
You have to clean off the disk or its broken for good
Posted on Jun 16, 2009
Ps2 doesnt read disc
You can clean the laser, although that isn't necessarily the problem. You can pick up a laser cleaning disk at any retail electronics store, such as Best Buy, RadioShack, and sometimes even Walmart. You can also open your Playstation 2 and use a Q-tip and rubbing alchohol to clean the laser. The problem is likely though that when you first loaded FIFA the data was corrupted on your memory card. Try deleting any FIFA data off of your card and then starting the game.
Feb 22, 2010 | Sony PlayStation 2 (PS2) Console
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
Ps 2 disc wont turn
I had this same issue with my PS2, honestly I think it was something to do with the laser eye reader that reads the disc, when it is dirty the disc won't even spin or attempt to read it.
you can either take an air compressor and when the ps2 is off, have the disc tray open and blow the dust out of it.
Or, i personally would take the ps2 apart and clean the diode itself with some rubbing alcohol. Just don't void your warranty or somehow break it.
This article will help you with disassembly: http://arstechnica.com/gaming/guides/2003/11/ps2-repair-guide.ars Hope this helps!
Mar 18, 2009 | Sony PlayStation 2 (PS2) Console
Will not load some games
I had the same problem with my ps2. I found a solution that might help you. take a Q-tip and dip it in rubbing alcohol or water just intil damp. gently clean the eye and the rest of the disk tray. then dry it the other end of the Q-tip. when the eye dirty with dust or a hair or a small speck of paper or plastic from a disk will slow the ps2 down when loading. hope this helps!
Feb 13, 2009 | Sony PlayStation 2 (PS2) Console
Will not read blue discs no problem with clear(silver) ones tho.
1. Apparently, blue PS2 discs are lighter than silver ones, so they tend to move around more when the PS2 is reading them. To fix this, you can put duct tape on the top of the disc. This will make it heavier, so it won't move around too much and it should make reading the disc easier for your poor PS2. People have told me that this indeed works (but not always). Don't go overboard with the tape though. Attempt at your own risk. 2. If the problems occurs when the PS2 is horizontal, try putting it into its vertical position. Or try putting it horizontal if it is vertical. 3. Use a can of compressed air to clean dust out of the system. 4. Make sure your game discs are not the problem. Keep them as clean as possible. Even small scratches can cause problems. 5. Open up your PS2 and clean it out or try adjusting the lens. Very risky and voids your warranty. 6. Try using a DVD lens cleaner (for problems reading silver discs) or a CD lens cleaner (for blue disc problems). 7. Send your system to Sony for repairs. Due to a lawsuit, Sony may have to repair your PS2 for free even if there is no warranty. Contact Sony for details. That is all the advice I can give. If the len(s) cleaners or compressed air don't work, then you are probably just out of luck. There is no magic way to suddenly get your PS2 working again without professional repair.
The trick to getting the discs to play on any PS@ (old or new) when they are black or blue is to put a piece of tape lengthwise and width wise around the hole in the disc on the topside (picture-side) of the disc. What this does is add weight to the disc and thus allows the PS2 to read it more accurately. I had bought many older titles not too long ago and was disappointed when they didn't work. Then I spoke with a Japanese expert online and he suggested using scotch tape around the hole in the disc and it worked instantly. Don't be fooled into buying a new PS2, just a roll of scotch tape. You'll only need four one inch strips.
Thank you for using FixYa - a FixYa rating is appreciated!!
Jan 27, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 slimline repairs
Its about the programming of your PS2, the only solution i now is to buy a new PS2.
Jul 31, 2008 | Sony PlayStation 2 Slimline Console
Ps2
thats got hardware failure written all over it call sony they might beable to help
May 21, 2008 | Sony PlayStation 2 (PS2) Console
Not read
turn off the system, restart by pushing green button hold until it clicks twice it should help..
Apr 21, 2008 | Sony Playstation 3 (PS3) Console
Eek Playstation 2 Slim wont read any disc!!
OK. First of all, put any disc in and turn on the PS2. Push the spot shown here down with something about the size of the TV end of the AV cable.
http://i142.photobucket.com/albums/r96/Daiv_The_Goriya/Pushdown.jpg
Watch what it does. Does it stop spinning? If so, see this pic
http://i142.photobucket.com/albums/r96/Daiv_The_Goriya/PS2problem.jpg
  1. This keeps the disc from spinning when the cover is open.
  2. push this down while following the instructions from the first pic. Does the disc work?
  3. There's usually a small object that pushes #2 down. Chances are it broke off.
http://i142.photobucket.com/albums/r96/Daiv_The_Goriya/Missingpiece.jpg
This piece here is what broke off on my PS2 as seen in the previous image. If you can find some way to glue it back on, you should be back in business.
Jan 30, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
