Computers & Internet Logo
r
rojnaman Posted on Apr 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cooler repair fan and motor broken repair connect parts
John Ray
Level 3:
  • Master 790 Answers
  • Posted on Apr 09, 2014
John Ray
Master
Level 3:
Answers
790
Questions
0
Helped
186509
Points
2180
If the pins on the mother board are sheared off, you will have to solder the connections directly to the motherboard.
You may want to replace the mother board
4helpful
Top fan is not working
. If the cooler recirculation fan is not working, use a Volt meter to test the two power lead wires connect to the motor . If the line voltage is present , replace the motor . Keep in mind this test should be done when the unit is in normal operating mode .
3helpful
Motor in wine frige is noisy???why
That motor is an evaporator fan motor. That noise occurs when the bushes in the motor start to wear. The motor is not in effect repairable but has to be replaced. Normally a 9 watt evaporator fan motor is installed into those wine coolers.
3helpful
2answers
NEED PART NUMBER FOR THE FAN ON A COLEMAN POWER CHILL ICELESS 12-VOLT COOLER.
Visit the Coleman replacement parts web site.
www.coleman.com/coleman/parts/PartsDefault2.asp
Our fan on our brivis evaporative cooler is not working. The pump to fill it with water is working and the fuse is fine. what else could it be - the unit is on the roof and I can not get to it.
there is a fan insert with a part Number 17517 this insert sits on the shaft of the motor. my fan is working but not blowing so i went up on to my roof and found out that this particular insert is broken (due to a birds nest )
2answers
Fan top back of unit is on and off continuely and making noise as in a failing bearing. I have removed the retaining screws, however the wiring has no disconnect to permit removal from the fan. Otherwise...
Unplug unit. Find name plate info on back of fan. It may be a 6 watt stamped CW. The rotation on small watt motors is based on looking at it from the "lead" end or rear of motor. You will have to cut the cord, WHEN UNIT IS UNPLUGGED. A new fan motor can be connected to the old cord with wire nuts. Install old blade on new fan motor.
2answers
Coleman Electric Cooler doesn't stay cold
the most common problem is that one or both cooling fans has failed. If you have the newer version, you can get replacement fans anywhere computer parts are sold
9helpful
4answers
Coleman 12-volt cooler stoped working/fan burned out
Sound like you have the newer version. These fans can be found at Radio Shack or anywhere computer parts are sold. It doesnt have to be an exact replacement. Just big enough to fit over the Cooling fins. Also make sure it's a 12 volt motor
Left side fan is not working
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing. A little oil inside teh motor and several revolutions later might get some relief until a new motor is installed.
4helpful
Hamilton beach water cooler is not cooling
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing. A little oil inside the motor and several revolutions later might get some relief until a new motor is installed.
1helpful
2answers
Danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
Grand Canyon Tech
Grand Canyon Tech
