Question about Maytag Atlantis MAV6000 Top Load Washer
Dead Wont cycle in any position, still filled with water
  • 6,784 Answers
Hi, this is a dead timer module. replace this defective timer control module asap.
Posted on Jun 19, 2009
Wont start wash cycle
The very first thing to check is that it is dead everywhere, and won't start on either fill or spin. If you find it won't start on a wash cycle - but it will work OK on spin then it may be related to not taking any water in - go here won't fill with water. Hack Free Robux HackFreeRobux
Dec 04, 2017 | Washing Machines
My washing machine wont fill up with water, what would the problem be, ive cleaned the hose at both ends so its not blocked?
usually the hot and cold water solenoid fail stopping water to flow
replaceable part
location
in where the hoses attach to the washing machine
May 09, 2016 | Washing Machines
It wont spin
Your washer has a lid switch.97a908d.jpg If the switch is broken the washer will not spin. The pump is mounted on the motor.c5ccc2f.jpg
In the wash cycle the pumps turns counterclockwise. In the spin cycle the pump turns clockwise, forcing the water out of the machine. So if that lidswitch is dead then she won't pump OR spin. This video shows how to get into your machine and the next one shows how to replace the lid switch
Use this GUIDE to help you
Did I help?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 28, 2010 | Roper RAS8445KQ Top Load Washer
Maytag Dishwasher - MDB6650AWW wont fill after initial fill
sounds like a bad module control. let me know if this helps with a 4 thumbs up post
Feb 27, 2010 | Dishwashers
Fills up the first tim but not after for the rest of the cycle.
it sounds like the fill float could be stuck in the full position and sticks during the rinse cycle check the float it is in the front to the left or right it looks like a bell, move it up and down and if necessary remove the front kick plate(s) and observe the mechanism as you move it up and down to ensure it is not hanging up.
Sep 11, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
Water will not stop filling wash basket, even when off
Your water fill (mixer) valve is failed in the open position.
CLICK HERE for the part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 20, 2009 | GE WBSE2090A Top Load Washer
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Cold cycle does not work
hey thats crazy.anyway first things first.water passes through the fill valve.in the valve[ where the black fill hoses attach to your washer] are screens that stop minerals from going into the valve itsself and blocking up the valve internaly.i know its going tobe tough[trust me i've done 100s]but its how your complaint is solved 99 out of 100 times.you turn off the water remove the cold hose and clean the cold fill screen.also while the hose is off flush it into a bucket or the washer tub[wont hurt a thing]make sure you put the screen back into the valve.so next time valve wont get harmed.if the screen is clean and you have water at the cold facuet at the washer.you could have a bad valve.that would be a voltage check.we wont go there now.if you still need help you can email me thru fixya.hope this helps. God bless ,tom
Jan 08, 2009 | Whirlpool LTE5243D Top Load Stacked...
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
