Question about Intel Motherboard
Gigabyte GA-6VTXE Motherboard cant detect any USB pluged It used to detect JUST SanDisks memory, now... not even that. All windows updates installed. In manufacturer site theres just a 4in1 driver set that didn't help. But they claim that the board has a USB 2.0 Help please, thanks in advance Pentium III 800 256 RAM Windows Pro XP SP2
    Problem Solver:
  • 4 Answers
The problem is probably not software, but hardware. The BIOS probably has disabled the USB controller, or the USB controller has probably gone out, the way to tell is when you restart the computer, when the screen first comes up, press the DEL key to access the CMOS setup utility. Check around for something that says "Onboard USB Controller" or "Onboard USB Support" and if it is disabled, enable it. otherwise the Motherboard has lost the controller and you either replace the board, or get a USB controller PCI addon card. Hope that helps.
Posted on Jun 16, 2009
Hey man i dont no to connect a u.s.b port in to a gigabyte mother board help me plz
Posted on Aug 06, 2009
4 Suggested Answers
SOURCE: Sound Card Drivers Intel PENTIUM-4 865GV mother board
i m using motherboard of intell pentium 4 can u help me for intallation of sound drivers or to download it thx zakir
Posted on Jan 18, 2009
  • 3 Answers
SOURCE: I have AWRDACPI motherboard, I want it's sound drivers for Win XP
HOW MAY I HELP YOU
Posted on Apr 09, 2009
the_fire
  • 432 Answers
SOURCE: Gigabyte 865 motherboard GA 8I 865 GVM SOUND DRIVER PROBLEM
none of the mixer lines are muted are they ?
If you double click on the speaker icon in the system tray or go to audio / sound in control panel and check in there.
Also have you got the speakers / headphones connected to the correct port ?
Posted on Apr 14, 2009
Sound card xp
download proper drivers use unknown device identifier,check the vendor and download from the computer manufacturer
Oct 19, 2013 | Gigabyte GA-6VTXE Motherboard
Usb dont work on gigabyte GA-K8NSC-939
i have some suggestions
1.the usb driver is not installed properly. if it's windows xp,you need to install it manually.you can download it free here
http://ee.gigabyte.com/products/page/mb/ga-k8nsc-939/download/
2.what device did you try to connect? it might be use USB 3.0 and your current USB is 2.0
Aug 22, 2012 | Gigabyte GA-K8NSC-939 Motherboard
GigaByte GA-8EGXR-P motherboard beeps when turned on - no video or BIOS - system does not boot
hi try to clean memory ram....clean it using eraser.....most of motherboard beep if memory not detected....or try other memory ram
May 10, 2011 | Gigabyte GA-8EGXDR-EL Motherboard
Not getting any POST (nor beeps) and monitor states "please check signal cable".
If there are no beeps, your computer is failing the POST. I'm assuming the system is actually powering up--you didn't say it doesn't.
I would disconnect all peripherals (HD, CD, any cards) and try to start with just the CPU, memory, and video. You could also swap memory sticks if you have more than one.
If it still doesn't start, I'd guess the motherboard is toast.
Oct 15, 2010 | Gigabyte GA-6VTXE Motherboard
Need max memory and hard drive size for Gigabyte GA-5AA motherbrd
Max Supported of your motherboard memory is 768 MB SDRAM DIMM(100,133,166,200 MHZ). You can find the full specifications here:
http://latam.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1439
Thanks for using Fixya
Jul 28, 2010 | Gigabyte GA-5AA Motherboard
Can I enable USB support in BIOS without keyboard?
I would first test your motherboard to see if it could do this. Most motherboards nowadays automatically detect USB keyboards and mice, and allow them to be used in the BIOS.
If this isn't the case, I would update your bios with newer firmware. Boot up the computer, check the Gigabyte website for these updates, and apply them (hopefully the computer will let you continue if it can't find the keyboard) After they are applied, the computer should be able to boot from USB.
Those are my two suggestions, but they are assuming you are lucky. If neither solution works, you may need to buy another motherboard, or see if you can clean the PS/2 ports with a can of compressed air, just in case it's a dust or dirt-based blockage preventing you from using them.
Hope this helps....
Jun 30, 2010 | Gigabyte GA-6OXET (GA-60XET) Motherboard
USB port not sensing after reinstalling windows xp, drivers are installed properly. not able to use usb stick, tried to access cam with usb port, nothing is working. pls help email id :...
Check your Device Manager "Start > Run > devmgmt.msc" you may have not installed controllers for your motherboard. Look for "!" and install the drivers using your motherboard driver disk. If driver CD is not available you can download updated drivers from Gigabyte Support Site.
Hope this helps.
Jan 04, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Gigabyte GA-8VM800PMD-775 @ 1.5gb memory
This is the website link for your board on gigabyte website. http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2159&ProductName=GA-8VM800PMD-775 Suggest you have a faulty piece of ram or a clock speed miss-match. your board supports up to 2gb of memory.Try also reseating the memory. Let me know how you get on? chris http://www.motherboardsrus.net
Jun 06, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
Motu MK2-2408 PCI-324 WIN-2000 and XP/ no conection to interface
check in control panal, check the following folder:
default programs, network and sharing center, problem report,
realtek hd audio m, sound,serity center, system, windows firewall,
last check windows updates
after that if you conitunueing to have these issues i will help you fether on this problem
rod is the candymangandy
Jan 26, 2009 | Gigabyte GA-6VTXE-A Motherboard
Problems during boot
this is windows unable to get to passed the lower bios memory before windows takes over with the normal memory. Check your cmos battery is'nt low, or reset the bios JBAT1 terminal from pins 1-2 to 2-3 then back again as the loop could be corrupt bios or a peice of hardware that cannot be started.
Jan 17, 2007 | Gigabyte GA-8N-SLI Motherboard
Intel Motherboard Logo
410 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
