Question about Canon PIXMA MX310 All-In-One Printer
How do i send a fax with my cannon MX310 what are the steps?
WHAT is the first thing you have to do?
press fax first or last? do i put in the fax number first or last then press fax? or do i press menu first? do i have to scan before i fax? when do i press ok?
behind the fax machine is a place to put a phone cord do i disconnect my phone and put the cord in there? or not? do i have to go OFFLINE to send a fax or not? Step by Step tell me how?
    President:
  • 3,085 Answers
Plug a phone line into the LINE port place original face up on the feeder dial the fax number press START (fax)
Posted on Jun 16, 2009
How to fax on the cannon mx300
Step 1:
Put the document you want to fax on the glass scanner.
Step 2:
Adjust quality and contrast to your liking.
Step 3:
Dial the recipients number
Step 4:
Press the "Color" or "Black" button.
After scanning the document press "Ok" to send the fax.
To do this you must first set up the Cannon mx300 for faxing.
More information can be found in its manual here:
http://www.copiercatalog.com/catalogfiles/PIXMA_MX_300_service.pdf
Aug 21, 2011 | Office Equipment & Supplies
Need instructions on how to send fax, it seem as though we are not following the correct steps
Solution: Sending faxes on an MX310
Sending Faxes
The operation flow of sending faxes is as follows.
  1. Load the original on the platen glass or on the Automatic Document Feeder (ADF).
    Platen Glass
    1. Lift the document cover (1).
    2. Place the original in landscape orientation and align the upper corner of it with the alignment mark (2) as shown in the figure below.
    3. Gently close the document cover.
ADF
  1. Remove any documents from the Platen Glass.
  2. Open the Document Tray.
  3. Load the document in the ADF.
    Load the document with the side you want to copy, scan, or fax facing up in the ADF.
  4. Adjust the Document Guides to match the document width.
  1. Press the button.
  2. Adjust fax settings as necessary.
  3. Start faxing.
    1. Dial the recipient's number using the numeric buttons or coded speed dialing.
    2. Press the button for color sending, or the button for black & white sending.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
    3. If the document was loaded on the Platen Glass, the following message will appear. Load the next page on the Platen Glass.
    4. If you have only one page of document to scan, go to step 5.
    5. Press the same button as you pressed in step 4b.
    6. Repeat steps 4c through 4e until all pages of the document have been scanned in and then go to step 5.
  4. Press the button.
  5. To cancel sending a fax, press the button. To cancel sending a fax while it is being sent, press the button, then follow the instructions on the LCD.
Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among three contrast levels.
  2. Press the button.
  3. Press the (left) or (right) button to select the contrast.
  4. Pressing the l_mark.jpg (left) button decreases the contrast, and pressing the r_mark.jpg (right) button increases the contrast.
  5. Press the button.
Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
  2. Press the button two times.
  3. Press the l_mark.jpg (left) or r_mark.jpg (right) button to select the resolution.
STANDARD:
Suitable for text-only documents.
FINE:
Suitable for fine-print documents.
PHOTO:
Suitable for photographs.
Return to Start Faxing
Back to the Top of the document
Dialing the Coded Speed Dial
  2. Press the numeric buttons to enter the two-digit code (00 - 19) assigned to the number you want to dial.
  3. Press the button for color sending, or the button for black & white sending.
    Note:
    * To cancel sending a fax, press the Stop/Reset button. To cancel sending a fax while it is being sent, press the Stop/Reset button, then follow the instructions on the LCD.
Feb 04, 2011 | Canon PIXMA MX310 All-In-One Printer
I AM FACING THIS PROBLEM FROM THE TIME I BOUGHT THIS MACHINE ie LAST TWO DAYS . HOW TO SEND A FAX ON CANON PIXMA MX320 ?
HI!The best and easiest way is to put in the document in the document feeder,dial the fax number and press the black start button as the color one will scan the document but not send it and give a error!!Good Luck!
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
I havent used the fax machine in quite sometime<<< i must be doing something wrong... im able to receive faxs but cannot send them, im sure im prolly doing something wrong can u give...
Hey!!The best and fastest way is to put in your documents in the ADF(automatic Document Feeder)Put the machine on fax,Dail your fax number and press the BLACK start button.Good Luck!!
Nov 05, 2010 | Canon MX310 Office All-In-One Printer
I can send faxes but not receive. Please walk me through the steps. When buttons do i press? It is a Cannon Super G3 fax machine. Thanks
Manual mode : when rings pick up the phone . press start and hang up .
Auto : you have to put your machine on auto receive .
press mode .
select fax only
Oct 25, 2009 | Canon LaserClass 2060P Plain Paper Fax
I just received a fax on my Cannon Mx310 but I
mailcenter12 --
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Sep 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Fax doesnt work
Go to control panel and open the printer. For faxing, make sure you have selected "Series FAX" and not the actual Printer.
This might be the problem
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Help with setting up my cannon mx310 fax machine.
here http://www.generalmanual.com/Printers/Canon-PIXMA-MX310-Office-All-In-One-Printer.htm you can download (under "download now" near the bottom of the page) the manuals you have lost.
Hope it helped you!
Dont forget rating.
Thx.
Jan 19, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
320 people viewed this question
old marine
old marine
