Question about HP Officejet 6310 All-In-One InkJet Printer
How do u reset power on hp office jet6310 - HP Officejet 6310 All-In-One InkJet Printer
    Guru:
  • 224 Answers
Connect the printer directly to the walljack without the surge protector and then power on the printer and without powering the printer off unplug the printer power cable from the printer as well as the wall jack wait for 30 seconds and then reconnect the printer first to the wall jack and then to the printer
Posted on Jun 16, 2009
How to hard reset hp photosmart 8250?
To do a hard reset:
1. Make sure the printer is on.
2. Pull the power cord from the printer.
3. Pull the power cord from the wall.
4. Wait 30 seconds.
5. Plug the printer in and turn it on.
Got these instructions from here: https://h30434.www3.hp.com/t5/Inkjet-Printing/Overriding-Ink-Expiration-Issue-On-PhotoSmart-8250/td-p/1943075
Apr 24, 2017 | HP Office Equipment & Supplies
How do i hard reset my hp photosmart 8250
To do a hard reset:
4. Wait 30 seconds.
C1AB0001 ERROR IN HP 8038 PRINTER
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
Mar 11, 2013 | HP PhotoSmart Office Equipment & Supplies
My catrige has a error
Wipe Down the Cartridge Contacts
Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
Remove the cartridge and use a clean, lint-free, dry cloth to gently wipe the contacts.
Wipe from the top of the contact to the bottom. Do this for each contact.
Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move onto Section 3.
Reset the HP Deskjet and Photosmart Printers
Turn on the HP Deskjet or Photosmart printer, open the cover and remove both the black and color cartridge. Close the cover.
Remove the power cord from the outlet and disconnect the cables running to the computer and/or router. Wait one minute, and then plug in the power cord and then the cables.
Open the cover and install the black and color ink cartridges. Turn the printer on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, you will need to buy new ink cartridges. Office Max or Wal-Mart have ink cartridges for almost every model of HP Deskjet, Photosmart and Officejet printers.
Reset the HP Officejet and HP PSC All-in-one Printers
Turn on the Officejet or PSC all-in-one printers.
Unplug the power cord from the back of the printer and wait one minute.
Plug the power cord back into the printer. Press the On button and hold until printer turns on.
Print a test page to see if this has fixed the problem. If not, you will need to buy a new color ink unit at any office supply store such as Office Max.
Feb 28, 2011 | HP Officejet J5780 All-In-One InkJet...
Hi how to solve hp 5610 office jet error 0*d0620130 reset power
You need to reset the printer
Follow the steps :
1. Unplug the power cord from the back of the printer while the printer is on
2. Press # and 6 button at the same time.
3. While holding them plug in the power cord
4. You will see a message on the printer Semi Full Reset - Release the buttons
Note : While doing it you will lose all the numbers which you have saved in your printer
Jan 07, 2011 | HP Officejet 5610 All-In-One InkJet...
How to reset hp 6213 office jet
take all the cable
press an hold the power button for 60sec and power it on
or u can try a semi ful reset by pressing and holding the # and 6 button togehther disconect the power cable and connect the power cable and while the printer is turning on release the #and 6
Feb 23, 2010 | HP Officejet 6200 All-In-One InkJet...
My printer hp office jet6313 all in ine, has a problem. whenever i want to print or scan document, i got a flashing messagw ''reset power'' this message keeps coming every time i need your help what should...
  1. check ink cartridge may be displaced or not secure within cradle causing power to continuley reset itself/ and then get back with me also check tht the ink is full
Jan 22, 2009 | HP Officejet 6310 All-In-One InkJet...
HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Won't turn on -- has a yellow question mark lit -- what do i do? HP Office Jet Pro L7680. Only thing lit is a yellow question mark.
here are the steps that i want you to follow.
PERFORM SEMI-FULL RESET
  1. While the Unit is turn ON, Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 6 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
Please, let me know if the steps resolve your issue.
Thank you so much.
adonscott
Jul 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
427 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
