Document Jam My Samsung SCX 4521F says it has a ''document jam'' (top feeder), but there is nothing in there. It won't copy or fax, but it will print.
  • 313 Answers
Check the photo sensor for the paper fed at the doc feeder roller section you can blow this out with air or try to clean it off you could also check the actuatot arm to see if the spring has com off.. usually its down to the paper dust on the sensor
Posted on Jun 16, 2009
  • Andy Bell
    Andy Bell Jun 16, 2009
    check the photo sensor for the paper fed at the doc feeder roller section you can blow this out with air or try to clean it off you could also check the actuatot arm to see if the spring has com off.. usually its down to the paper dust on the sensor
Samsung SCX-4521f Document Jam with no paper jammed
u can clean sensor in your printer, i mean all sensors.
Jul 05, 2014 | Samsung SCX-4521F Laser Printer
Display document jam
that normally refers to the document feeder on the top of the machine, take A damp cloth and clean the rollers that pull in the paper, also check that there is no pieces of paper left behind from A previous paper jam, that will affect your paper sensors
Oct 29, 2012 | Samsung SCX 4521F All-In-One Laser Printer
Hi I have a Samsung scx-4521F I am trying to send and receive Fax over IP now I know that I have to change the Baud rate to the lower one. but How can I do that? other than changing Baud rate what do I...
I have a samsung scx-4521f i am trying to copy some document but i cannot copy clean. my printer was copy in document black line or black paper ground what do i need to clean copy ? please help me.
Sep 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Paper Jam message on every print job.
I have the same printer without the doc feeder. Check the paper trail thru the printer for the paper sensor lever hanging up. It gets pushed up by the paper and can stick, making the printer think it still has paper in it. Pulling the cart unsticks it till you print again.
Jul 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
SCX 4521F multi/f keeps reporting "Document Jam"
Hello there,
If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Feb 12, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Scanning / faxing problem
you will need to replace the adf assembly or the portion of adf roller which was dameged.
typically one should open th ecover and take out the jam inth direction of papermovement only
happy faxing
omnipresent
Oct 17, 2007 | Samsung SCX-4216F All-In-One Laser Printer
173 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
