This weekend the dishwasher stopped cleaning the dishes. The dishwasher sounds like it goes through all the cycles. It still beeps when done and when I open the door steam still comes out. But the dishes are still not clean. I took both the bottom and top washer bars out they were blocked I unblocked them. Today I washed another load and the dishes were not clean.
My Siemens SL84A305UC/21 dishwasher will not drain. I've checked the drain and it is clear. I can...
(More)
My Siemens SL84A305UC/21 dishwasher will not drain. I've checked the drain and it is clear. I can hear the motor hum during the drain cycle. It will fill and wash OK, but not drain. Does this machine have a solenoid for draining and if so how do I check it? How do I check the pump to ensure it is functioning correctly? I've tried to remove the plastic bottom of the machine to see what is inside and to troubleshoot the components, but it seems almost impossible to remove. What is the trick? What and how should I troubleshoot the machine?
well that's basically it. the pump is humming as if it's working, but it doesn't drain. It's been...
(More)
well that's basically it. the pump is humming as if it's working, but it doesn't drain. It's been working flawlessly for 5 years now, and I haven't moved it around, so it shouldn't be the hose? I've read maybe I can push two buttons, and the system will reset, I just don't know what two buttons? I hope you can help.
