Question about Hayward 12v LED Color Logic Pool Light -100ft Cord - SS Face
My Hayward Colorlogic pool light is flashing like a strobe light.
  • 640 Answers
That particular swimming pool light has a power-cycle feature that allows you to change the way your light illuminates your pool simply by turning it off and on. A strobe like effect is one of these power cycles. To change it, simply turn the switch off and then turn it back on within 10 seconds. It should reset to another cycle. It is is left off over 60 seconds, it resets to the first cycle, which could be the strobe. If cycling doesn't solve the problem, your bulb has probably malfunctioned and you are going to have to have a repair tech service it.
Posted on Jul 14, 2010
    New Friend:
I had the smaller one of these lights in my spa and the larger one in the pool. They have been trouble free for 8 years but the other night the spa light would come on and flash a couple times like a strobe and go out. I checked the transformer and it was ok. I took the light apart and the power lead on the positive (black) wire was broken off of the circuit board. 10 min later and resolder of the connection and its good as new. Check those connections before buying a new lamp.
LEDs run HOT. If the connection wasn't good from the factory then in time they will fail.
Posted on Jul 31, 2016
    New Friend:
I have 2 led lights in my pool 1 of them is flashing how do I fix that
Posted on Jul 10, 2014
2 Suggested Answers
  • 246 Answers
SOURCE: Hayward Colorlogic Light flashes like a strobe
OK I GUESS U HAVE A AUTHOMATIC CONTROL CHECK T RELAY FOR 120 V THAN CHECK FOR V AT THE JUCTION BOX IF V LIGHT MUST BE REPLACE.
Posted on Sep 17, 2009
My hayward colorlogic light goes on for a few seconds and then remains off
overheating if 12 volt unit check voltage from transformer if ok bad light
Jun 19, 2018 | Hayward Pool & Spa
Equipment is hayward 2100.I replace pump for waterwall but doesnt want to start.Main pump is working.Control panel from outside is broke there is no lights on.From inside the house is working.I try to...
I think I just answered you question before, I provided service manuals and a few other pints.
www.haywardnet.com/products/Manuals/pdfs/Manual104.pdf
www.haywardnet.com/products/manuals/pdfs/manual100.pdf
www.platinumpools.com/files/.../Colorlogic%20LED%20Light.pdf
www.entretech.ca/documents/products/heaypump/haywarden.pdf
www.pool-heater-world.com/hayward-heat-pump-4pools-spas.htm
OK these links should help you out.
As related you need to check if there is Power to the motor, check all sensors, and troubleshoot as per above to isolate the fault.
May 21, 2010 | Pool & Spa
I have 2 light colors in my pool in one of them When I turn them on one just flashes
LIGHT SYNCHRONIZATION If your pool or spa has multiple Hayward ColorLogic LED lights, they may be operated independently, or they can be easily synchronized so they will all display the same colors and shows at the same time. For light synchronization, all lights must be wired to the same switch. Once installed, all lights should be automatically synchronized, however, if they get out of sync, they can be re-synchronized easily. To re-synchronize your lights, turn the switch on, then back off, then wait between 11 and 14 seconds and turn the switch back on. When the lights come back on, they should enter program #1, and be synchronized.
Feb 15, 2010 | Hayward 12v LED Color Logic Pool Light...
Jul 07, 2009 | Hayward 12v LED Color Logic Pool Light...
Colorlogic Pool Light flashes like strobe
These swimming pool lights have a power-cycled feature. THis means that you can power down the light and then power back up in 10 seconds and the light pattern will change. It sounds like your light is not cycling properly. Power it down for a full 60 seconds. This will reset the power cycle. Then try turning it on and off in 10 second intervals. If it doesn't reset, you bulb may only be partially functioning and it may need to be replaces.
Jul 06, 2009 | Hayward 12v LED Color Logic Pool Light...
My hayward colorlogic pool light flashed like a strobe light. After repeatedly turning it off and then on again, it now will flash light for less than a second and then turns off. Spa colorlogic works...
You should check your ground fault and reset if necessary. This particular swimming pool light should cycle through a variety of different light shows by turning the switch on and then off for no more than 10 seconds. If it is not cycling properly, you might be leaving the swith off for longer than 10 seconds or your bulb might have malfunctioned.
Jun 28, 2009 | Hayward 12v LED Color Logic Pool Light...
Multi color light will not come on/only flashes a second
These swimming pool lights are have a power cycle function. It could be that your power cycle is not working properly. Turn the light off for more than 60 seconds to let it reset. Then turn it on and off in 10 second intervals. If the color does not change or the light does not stay on, and you have tested your ground connection, then you will probably need to have your bulb replace.
May 28, 2009 | Hayward 12v LED Color Logic Pool Light...
Hayward 12v LED Color Logic Pool Light -100ft Cord - SS Face Logo
4,348 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
