We have an older 3 year 42" Hitachi Plasma TV. There is a black line about 2" wide running down the screen from top to bottom slightly off center. Sometimes it goes away and sometimes it doesn't.
    President:
  • 2,187 Answers
You may have bad connections inside the TV. Either loos cables (flat cables) or loose IC that needs soldering.
You may want to check videos below on TV repairs. I cannot find a Hitachi but the approach is almost the same. I would advice caution if ever you want to try it out.
Video 1 / Part 1
http://www.youtube.com/watch?v=9NPobj0_GSo
Video 1 / Part 2
http://www.youtube.com/watch?v=ITd6Ahdi4s0
Video 2
http://www.youtube.com/watch?v=qBpg77ZzFFk
Posted on Jun 16, 2009
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Random 3'' vertical red line on 42'' Hitachi Plasma TV
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Plasma color TV screen developed dense black vertical line
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Sep 21, 2009 | Hitachi SSH2442 Television
Black line on plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 19, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
HITACHI CMPAD14D 42 in plasma it has a black strip some 3 inches wide runing near the middle of the tv from top to bottom and it some time comes on then dissapears and so on and so forth
hITACHI CMPAD14D 42 nel plasma ha una striscia nera di circa 3 centimetri runing ampio vicino al centro della tv da cima a fondo e che da qualche tempo si accende poi scompare
Oct 02, 2008 | Televison & Video
Plasma t.v
My hitachi tv # 42EDT41 A 42 in. has a black line from top to bottom on the left side of screen
Dec 23, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black line in center of screen
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is tomp2000@juno.com.
thanks,
ST
Jan 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
