Question about Lexmark X1270 All-In-One InkJet Printer
How to use buttons on Lexmark printer, plus having problems it tell me not connected .
I have printed with it  once, but now it won't let me print. can scan and send but no printing .    also which buttons do you use on the printer itself,    Looked in directions and it says to use buttons but no explanation for which one is what.    Thank you.
         Tells me no communication with the printer, so how do I solve that?
  • 2 more comments
  • 1958 Nov 01, 2007
    Yes have problem fixed . Thanks
  • Steff88 Feb 06, 2008
    I'm having the same problem they tell you what the buttons are called, does anyone know where the copy button is on these printers?
    There online teach support and there e-mail support aren't very good I can't even find out where to go to get the online support.
    from Steff
  • Anonymous Mar 11, 2008
    wich buttons to press to print
  • rclobo Jan 06, 2009
    LEXMARK X3650
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 29 Answers
Make sure that you have the Lexmark "All In One Center" installed - that's usually the problem when you get communication errors.
First, you'll need to install the software and driver for this printer:
  1. Make sure you have the regular printer driver installed. If you don't, you can grab it from the Lexmark website and install it.
  2. Next, keep your USB cords plugged in but turn your printer off.
  3. Download the All-In-One Center Software here.
  4. Unpack the archive, open the "Applications" folder, anddouble-click Setup. This will install the application - it can take abit.
  5. Once the application is installed, turn the printer on and try a test scan. If it works, you're good and can quit reading.
  6. If you get an error when running a test scan, don't panic.Reinstall the regular printer driver, using the "Update Driver" optionthat appears.
  7. Restart your computer.
  8. Do a new test scan. This should bring up the All In One Center'sloading screen, which will start searching for programs (this canreallllly take a while). When it's done, everything will be workingbeautifully again!
Then, hit Lexmark's site for the Setup Sheet and User Guide available here.
Posted on Jul 07, 2009
2 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: lexmark x7550 won't communicate with computer
    A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
    If that doesn't help, try the steps below:
    1. Disconnect the printer from your computer.
    2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
    2. On your computer, go to Control Panel > Printers and Faxes.
    3. Delete the Lexmark print object.
    4. Reboot your pc.
    5. When your pc turns on, reconnect the printer.
    6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
    You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ngaKcu. Select your operating system, download and execute the file.
    Posted on Oct 19, 2011
    Not able to print
    A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
    1. Disconnect the USB cable connecting the printer from your computer.
    4. Reboot computer.
    5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
    6. When the printer turns on, reconnect it to the computer.
    7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
    Jan 25, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
    Wont scan
    4. Reboot your pc.
    Nov 09, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
    Lexmark x7550 won't communicate with computer to scan
    4. Reboot your pc.
    Oct 19, 2011 | Lexmark X7550 InkJet Printer
    My Lexmark 4650 keeps telling me that my margins need adjusting, plus it is giving me blurred copies.
    Check Page Preview before printing your file and see if the application you are using recognizes the entire page and does not cut-off the edges.
    You can try to print Fit to Page or Borderless and see if that helps.
    For your blurred copies, Please follow the steps below to fix your problem:
    1. From the printer operator panel, press the Setup button.
    2. Go to Maintenance.
    3. Select Align Cartridges. Your printer will then print a page to align your cartridges.
    4. After the test page is printed, try to print a document again to verify that the problem is fixed.
    Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
    Oct 19, 2011 | Lexmark X4650 InkJet Printer
    I have a Lexmark X8300. All was ok till recently. I can print out anything from the computer but can't use the copy feature. Also, all of the lights stay on - the copy light, fax light, scan light,...
    2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
    4. Reboot your pc.
    6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
    You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eO4Y77. Select your operating system, download and execute the file.
    If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
    Aug 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
    "Communication Not Available" message is displayed
    2. Unplug and re-plug the printer into the power source to reset it.
    4. Reboot your pc.
    6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
    You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
    Aug 16, 2011 | Lexmark X2670 All-In-One Printer
    Hi - my x4550 lexmark printer wont print, can you help?
    If your printer won't print when you're making a copy using the Copy button on the operator panel, it could be due to your ink cartridges. Try to re-seat your ink cartridges into the printer and make sure they are properly seated.
    If you're not able to print from your computer, it could be a communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
    You may refer to this article for Wi-Fi connection issues: How to identify a Wireless Communication Problem and Resolution Tips
    Aug 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
    PRINTER WILL NOT RECOGNIZE PRINT CARTRIDGES. KEEPS GIVING ME ERROR MESSAGE REGARDING COLOR PRINT CARTRIDGES (EITHER WILL NOT RECOGNIZE OR TELLS ME IT IS INPUT INCORRECTLY). WILL NOT LET ME PRINT IN JUST...
    The firmware update for the Lexmark Pro205 printer will help fix the problem where the printer is having trouble recognizing the ink cartridges and other issues. You can download and install the update for your Lexmark Pro205 printer by visiting the Lexmark website at http://bit.ly/p205fw. If more than one download is available for your model, try the top download first.
    May 06, 2011 | Lexmark Prospect Pro205 Wireless...
    No power on my Lexmark X8350
    That's the same printer I have.
    First, make sure the blue "copy" button is lit. Printing is done there.
    Then, go to the circle with the checkmark in it and hit the menu, and arrow down to copy papy size and make sure it says "letter".
    Click start on your computer, then click control panel, then printers, and make sure Lexmark 8300 series is the default printer and has a green checkmark in a circle.
    If all these things are right, you should be able to print a test page and the computer should work fine.
    If any one of them are wrong they must be corrected. If you need help on any one of those please write back.
    Sirwriter
    May 14, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
    Lexmark 2380 plus won't stop printing
    i think its a firmware issue for me..
    I experience it before with my printer ..
    I just flash with another firmware..
    and if the problem still exist..try to
    uninstall printer driver and install another one.^_^
    May 13, 2009 | Lexmark 2380 Plus Matrix Printer
    Lexmark X1270 All-In-One InkJet Printer Logo
    1,256 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
