Home | Hobart | 25 in. LXIH-4 Built-in Dishwasher | Just purchased a use...
Hobart 25 in. LXIH-4 Built-in Dishwasher
Problem for Hobart 25 in. LXIH-4 Built-in Dishwasher
Just purchased a used LXIh4 temp on diplay only goes to 155F
By spaulelec on Jun 16, 2009
first run went to 170f but susequent load only went to 155 unit is fed with 120f supply
Best Solution
posted on Jul 01, 2009
Very Helpful)
AbsoluteServ
Rank: Guru
Rating: 90%, 51 votes
The incoming water determines how fast the DW is ready for another cycle. For running continuous cycles, the incoming water will need to be 140 degrees. If you pause 2 minutes between cycles, the temp should remain consistent with a 120 degree supply.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hobart 25 in. LXIH-4 Built-in
Questions and Unsolved Problems for Hobart 25 in. LXIH-4 Built-in
Do you recommend Hobart 25 in. LXIH-4 Built-in Dishwasher?
Answer
Answer
We had a power black out. When the power came back on, the machine is stuck on a 12 minute rinse... (More)
Answer
water left in bottom of ge evolution dishwasher.
Answer
Our dishwasher's upper spinning arm is clogged with food particles. Can I remove this, open it up... (More)
Answer
My machine stops after starting and wash cycle and flashes ''Problem'' '' D 1''
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hobart 25 in. LXIH-4 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
