Being asked to reinstal CEC_MAIN.exe how do i do this
  • 1,271 Answers
The CEC_MAIN.EXE belongs to the Camera Assistant software. The file you find on C:\Program Files\Camera Assistant Software for Toshiba.
Uninstall the software then reboot, reinstall.
Regards
GeWiz.
Posted on Jun 16, 2009
How do the hmi on tv withe control
How to Enable HDMI-CEC on Your TV, and Why You Should
www.howtogeek.com/.../how-to-enable-hdmi-cec-on-your-tv-and-why-...
Jan 16, 2015 - The devices can have some control over the TV, and the TV can have some control over ... AOC: E-link; Hitachi: HDMI-CEC (Thank you, Hitachi!) ...
How to find out if your device is HDMI CEC capable?
hdmicec.blogspot.com/.../how-to-find-out-if-your-device-is-hdmi.html
May 18, 2012 - Hitachi - HDMI-CEC ... You can control your computer with your TV'sremote control and you can set up that your laptop shuts down or goes to ...
[PDF]OG S606 U516 Eng - Hitachi Service
Dec 26, 2015 | Hitachi Gst Hitachi 46" Class LED-LCD...
Where do I find the cec connection for setting timing?
cec.
timing of what, cam or spark.
what engine, is there.
Computerized Engine Control or Computerized Emission Control (CEC)
the 4.0L and 2.5 liter , uses the RENIX ecu. and not the CEC. tje REnix has fixed, CKP sensor timing.
the 4.2liter has distrib timing.
see below.
my guess is you have the instructions and
get lost at the find VACUUM switch on top of valve cover words?
yes?
Jun 28, 2015 | 1988 Jeep Wrangler
Is my Sony Grand Wega Consumer Electronics Control (CEC) compatible?
Consumer Electronics Control (CEC) What is Consumer Electronics Control (CEC)?
Consumer Electronics Control or CEC is a function that allows you to control multiple devices over HDMI using one remote control by having a secondary device receive commands from a primary device. Although CEC wiring is required for every HDMI port it does not mean that every HDMI port will have the function enabled.
If your device has the CEC function, this information will be located under your setup or settings menu.
To enable the function you will need to turn the CEC function on and then search for any devices that are CEC enabled that are connected to the TV.
Was this article helpful? 2 out of 4 found this helpful Have more questions? Submit a request
Related articles
Jun 13, 2015 | Sony Grand WEGA KDF-50WE655 50" Rear...
Is there an option to turn off cec. So I can use ir control .
Go into the menu on your device. Look for HDMI settings. There is normally an option to turn off HDMI CEC. A lot of manufacturers have their own name for CEC, so you may have dig a little to find it.
Feb 14, 2015 | Televison & Video
I have a WD Elements 1TB external hard drive. I want to use it as an additional hard drive for may laptop. There is one specific program that I would like stored on the hard drive. How do I transfer the...
the easiest way to achieve this is reinstalling the program on the hard drive. Select advanced installation, and when it asks for a path, give your hard drive's path.
if you can't reinstall it, it'll be a little bit more complicated.
if it's on Windows, you'll have to go into the "Program Files" folder, find your program's folder, and copy it into a "Program Files" folder (you have to create this one). Then find the main exe file in the program's folder you copied (usually <program name>.exe, right click on it and select Send to desktop (or create a shortcut) in order to access it more easily.
That's it.
if you need more details, feel free to ask.
Antoine Viallon
Dec 16, 2017 | Western Digital Elements 1TB USB 2.0 Hard...
I have Toshiba laptop with built in camera, but whenever i try to open the camera i recieve an error message 'CEC_Main.exe' reinstall. Kindly help how do i go about.
You also have Kasperkey ?
The error message 'CEC-MAIN.exe' is connected with the Camera Assistant Software,
You are unable to run the camera software because your KIS (Kasperkey Internet Security is blocking it by keeping "CEC-MAIN.exe" in the 'Untrusted File'.
Resolution:-
1) Launch your web browser
2) In the Notification Area (Down by your clock - Right click on the KIS icon and select "Pause Protection" > select "Resume manually"
3) In Notification Area: click on KIS icon elect "Applications under Control"
4) In the "Applications under Control" menu relocate "CEC-MAIN.exe" from the "Untrusted File" to the "Trusted File" - click "OK"
5) > Start > All Programs > CEC-MAIN icon to run your web camera program
Or My computer >> Local Disk (C) >> Program Files >> Camera Assistant Software Folder >> CEC-MAIN icon
Your webcam should now be running
Worth putting a shortcut on your Desktop at this stage .
6) With the webcam still running, then In notification Area - Right click on the KIS icon and select "Resume Protection"
7) Check the "CEC-MAIN.exe" in "Applications under Control" and confirm it is still in the "Trusted File"
8) Restart your computer
Aug 19, 2010 | Computers & Internet
Lost "camera assistant software for toshiba\cec main.exe.can you help?.
Hello ,
You may need to go to the manufacturer to download the software & drivers ,
You may also may need to scan your system for infections to see if that software is infected and unable to load & work , their is several place to have your system scaned for free or scanned and repaired for a small fee / just make sure that the company is reputable as in
Symantic , Mcaffe , Panda Security
also try rolling back the driver for you may have gotten a bad update for the software or driver / this is done thru the device manager
Feb 22, 2010 | ASUS Eee 4G Notebook
It says can't execute CEC Main, reinstall program
This is what I know about this issue. I'm guessing you have a built in camera and anti virus program installed on your laptop. What you will have to do is to uninstall the driver for the camera, and disable your anti virus for a while. then you can reinstall your camera and it should work.
If you need further assistance with the procedure, let me know and I will help you with detailed instrucations. I will need to know what anti virus you have and which windows you have installed
Dec 02, 2009 | Toshiba Satellite L305-S5907 Laptop
Ceccmdll.dll cec-MAIN.EXE HAS STOPPED WORKING
Have you just installed a new security app such as Kaspersky?
If so you could so allow CEC_main.exe in the firewall which should cure the problem.
Sep 10, 2009 | Gateway Computers & Internet
HD Video Recorder - CEC connection with HDTV
My first question would be, Is your Panasonic HD recorder CEC compliant? CEC means Consumer Electronics Control. That simply allows for the consumer to have better control over their Home Theater set up through the connection of you HDMI cable from their remote control without programing the remote control for every single device that is connected. If your recorder is CEC compliant the television should have automatically recognize the recorder and control you recorder via remote control (I am assuming that your recorder is an HD Camcorder, since your description was very vague). Once you connect your HD camcorder to your panasonic tv the tv should have turned on switching to the correct input and the same for any other CEC comliant devices. If your Panasonic HD recorder is not CEC compliant the you would have to start viewing your recorder the old fashion way, by using the recorder remote control or if your Toshiba remote is universal punch those codes in so that you can control your devices that way. If that don't work, try a different HDMI input and select the input and make sure your recorder is set to output on you tv. Hope this helps.....before I forget, check out this site to learn more about Consumer Electronics Control (CEC) http://www.videsignline.com/howto/207400325
Nov 23, 2008 | Televison & Video
Computers & Internet Logo
75 people viewed this question
Alun Cox
David Payne
David Payne
