Question about Panasonic PT-44LCX65 Television
BLUE SPOTS I HAVE A 2005 PT-44LCX65 AND I AM SEEING TWO BLUE SPOTS LOWER LEFT SIDE THAT SHOW UP WHEN THE BACKGROUND IS A LIGHT COLOR. THERE IS ALSO A SLIGHT GREEN AREA THAT SHOWS WITH CERTAIN BACKGROUND COLORS. IS THIS DUST OR SOMETHING WORSE TY, mICHAEL
  • 868 Answers
Degauss
Posted on Jun 03, 2008
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Tip
PANASONIC WITH FUZZY SPOTS
FIXYA TIP PANASONIC
I hope this not AN old TIP, but I still see it asked and not answered properly by some.
TIP:
PANASONIC:
MODELS: PT-44LCX65, PT-52LCX15, PT-52LCX65, PT-52LCX35,
PT-61LCX65, PT-61LCX35.
SYMPTOMS:
1. FUZZY SPOTS
2. FUZZY SPOTS WITH STAINS
3. FUZZY SPOTS & UPSIDE DOWN
4.. FUZZY SPOTS WITH LINES
5. LOOK LIKE BAD LIGHT ENGINE.
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM CORRECTION TOOL; (LSUQ0100).
It is an easy repair (about 7 minutes), it takes longer to take the back off to perform this procedure.
Can't be purchased unless you have an account, customers can not purchase.
Thanks, Big IRISH.
on Dec 15, 2009 | Dishwashers
Three Green spots and one purple one on screen.
Here's the scoop about the spots!!! Apparently Panasonic knows about the problem!! It is a corruption in some eprom. Call Pana or your service center and they will get someone to come to your home and fix the problem ...no charge!!! I had mine just done, it takes about 15 minutes tops!!
Aug 29, 2009 | Panasonic PT-44LCX65 Television
Panasonic tv model pt-44lcx65
Howdy,
The problem is with the EEPROM in the TV that needs to be reprogrammed. But you need to have the proper Correction Tool (LSUQ0100).
I don't think it's available to the public. Call a Service Company, but make sure they have the “Correction Tool”.
Thanks for using FIXYA, big IRISH.
May 27, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Green Spot
set your tv to original default factory settings.
then apply also good resolution.
your problem is most of solved
Mar 24, 2008 | Panasonic PT-44LCX65 Television
3 blue spots
Just have Panasonic tech do "eprom upgrade".
Jan 08, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-44LCX65 Television Logo
236 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
