Android touchscreen tablet model:HHQ17 has stopped working. it was closed and when i opened it the battery which is full flashed a few times but won't stay on, i tried to connect to the keyboard and still nothing, only a black screen
Is it a pipo m8 model ? not getting a listing for this model, if you have it on charge does it still do the same thing, blank screen could be the sd card inside has fell out. this is on some models has an 8gb - 32gb sd card inside. other models it can be a read error of may ram. if it has volume controls on the side hold down the power and volume down at same time and then lift fingers off and see if the android software comes up, can take a few times to get it up takes a bit of practice to get it up but does not work on some. when the menu comes up you will have a list of things you can do choose the one you want to do reset system last know good etc and see if that fixes it. failing that you will need to open the tablet up and remove the battery and check the sd card if it has one inside.
SOURCE: Touchscreen has stopped working on the tablet I
its a software problem try reinstalling the software
SOURCE: Coby touchscreen internet tablet for android will
I would guess that it overheated. You aren't supposed to leave them plugged in for extended periods of time.
SOURCE: android tablet touchscreen keyboard broke and won't uninstall
first repair touchscreen and then set factory settings.
SOURCE: I downloaded Skype on my 4Sight 9" Android 4.0 tablet but it won't open. How can I fix it?
I've had trouble with downloaded apps not working and everytime I did I would delete the app, turn my device off then back on, and then reinstall the app.
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
2) On/off switch is broken.
Good Luck,
dean.
